swapping parts from crx into civic...questions.
Old Nov 6, 2005 | 04:42 PM
slammedef06's Avatar
Default swapping parts from crx into civic...questions.
i have a 90 crx dx and i just bought a 91 civic hatch std. i want to swap over a few things please tell me if these will fit.... 90 crx to 91 civic...
CRX seats into Civic?
CRX Carpet into civic?
CRX Gauge Cluster(has rpms, 90 crx cluster into 91 civic hatch)?
thanks
Old Nov 6, 2005 | 04:44 PM
Stunna MIKE's Avatar
it should..
Old Nov 6, 2005 | 05:39 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: swapping parts from crx into civic...questions. (slammedef06)
i bet the crx dash would look sick in the civic, ive seen it before.
Old Nov 6, 2005 | 05:42 PM
CoreyR's Avatar
Default Re: swapping parts from crx into civic...questions. (stocker2shocker91)
all that **** should fit. i know the cluster and seats will for sure. the carpet from the firewall to the front seats will be the same but i dont know about the floor in the back of the hatch cause it has seats and the CRX doesnt.
Old Nov 6, 2005 | 05:45 PM
z6's Avatar
z6
actually the seat dont fit unless you put the civic rails on the crx seats, from what ive read
Old Nov 7, 2005 | 06:03 AM
vtecn8ive's Avatar
Default Re: (z6)
I believe just the guage cluster.
Seats won't different bolt points I believe. I know for 88-89 civics and 88-89 crx don't intermix.
Carpet shouldn't since its a different lengths but I guess I 'm not positive.
Old Nov 7, 2005 | 06:37 AM
iTe4LIFe's Avatar
Default Re: (z6)
"actually the seat dont fit unless you put the civic rails on the crx seats, from what ive read "
that's probably doable....
if you keep your hatch seat pan, you can put the crx seats in your car.. actually you should be able to put any honda/acura seat in your hatch if you keep the hatch seat pan.
the dash... i believe all hond/acura dashes are interchangeable.. when i get into some cash I'm going to hunt down an rsx dash for my std. the crx dash is sweet though; i love rex's. Why are you getting rid of yours?
Search on honda tech for the seat pan swapping.... there's a few write ups available and it's easy to do.
Old Nov 7, 2005 | 06:40 AM
vtecn8ive's Avatar
Default Re: (islandtechengineers)
He never stated anything about dashes.
An no not all dashes are interchangable.
88-91 CRX and Civic HB are interchangable
Old Nov 7, 2005 | 02:54 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by islandtechengineers &raquo;</TD></TR><TR><TD CLASS="quote">"actually the seat dont fit unless you put the civic rails on the crx seats, from what ive read "
Search on honda tech for the seat pan swapping.... there's a few write ups available and it's easy to do.</TD></TR></TABLE>
no the seat pan swapping trick doesnt work on every seat. i couldnt do it with my del sol seats into my 91 si.
Old Nov 7, 2005 | 03:22 PM
yea i kno my bad a little off topic but i didnt know if u thought about it
Old Nov 7, 2005 | 03:27 PM
Drew17th's Avatar
the gages fit perfectly i know cuz i just took 91 hb gages and put them into my rex because my entire interior was stripped awhile back and ive been replacing everything lol... o yea you will have to drill new holes for the rails... its not to bad tho.... i just put 94 civic ex coupe seats in my crx looks good and not to much work
Old Nov 8, 2005 | 05:03 AM
iTe4LIFe's Avatar
"An no not all dashes are interchangeable."
correction accepted; I always thought they were because I’ve seen a nice range of swapped dashes.
“no the seat pan swapping trick doesn’t work on every seat. i couldn’t do it with my del sol seats into my 91 si.”
Once again correction accepted, I always thought they were because of what I’ve been reviewing of everyone else who’s tried it. That’s weird, I read somewhere (to bad I didn’t save the link) that someone put 92 – 95 civic sedan seats in a 90 rex; I thought it would have been do-able with a del sol (considering it’s also a 92-95).
My next suggestion then would have been to align, drill and tap holes for the seats… as someone has stated above me. Oh well… hey good luck with your swapping.
88h22_CRX
Nov 26, 2013 04:49 PM
FWDrifter559
Dec 11, 2011 07:08 PM
Edison Carasio
Aug 10, 2010 03:06 PM
crxjarred
Aug 9, 2008 01:40 AM
london_civic
Mar 14, 2004 05:13 PM
