Suspension & Brakes Theory, alignment, spring rates....
Omnipower height adjustment question
Old Nov 6, 2005 | 04:05 PM
MilanoRS's Avatar
Default Omnipower height adjustment question
i have 94 integra rs with omnipower street coilovers. i've had them on for more than 6 months and i dont want it as low as it is npw.
problem: i cant raise the height in the rear.
i loosen the lower collar lock and i try to turn the shock body counter clockwise. the shockbody doesnt move at all.
Old Nov 6, 2005 | 04:23 PM
PIC Performance's Avatar
Default Re: Omnipower height adjustment question (MilanoRS)
Try this: tighten the spring perch and spring perch lock against each other as tight as you can get them. Then with a spanner wrench turn either one of those (they should turn as one piece) and the shock body should turn as well, to raise or lower the car.
2000EJ8
Suspension & Brakes
Apr 30, 2010 07:20 AM
joe.wong321
Dec 16, 2007 02:19 AM
slow_ls
Suspension & Brakes
Nov 17, 2006 06:11 AM
OutlawCL
Suspension & Brakes
Mar 6, 2006 09:51 PM
grampafunk
Suspension & Brakes
Apr 19, 2005 02:27 PM
