Cannot loosen valve locking nut or screw
Old Nov 6, 2005 | 03:10 PM
PLAGUED_DB7's Avatar
Default Cannot loosen valve locking nut or screw
WTF? I did a valve adjustment about a year ago on a friends car...now I go to do it again and I cannot move the nut or screw for ****. Its like they seized. Any suggestions??? His specs are way off too. In .09mm and EX .17....He put about 45k on it...he drives hard too man I only got 1 hour of daylight left...help
Old Nov 6, 2005 | 03:17 PM
kchungb17a's Avatar
Default Re: Cannot loosen valve locking nut or screw (PLAGUED_DB7)
What are you using to try to loosen it? Try getting a socket on a ratchet (give yourself some leverage) to loosen the nut. Just be careful not to hurt yourself or the engien. I don't see how they can seize unless it was severly overheated.
Old Nov 6, 2005 | 03:30 PM
Default Re: Cannot loosen valve locking nut or screw (kchungb17a)
yeah I have tried a rachet, open end, closed end, breaker bar...The ****'s dont move..also one of the rocker arms is worn flush..only one. I have never seen that happen before. I checked out my rockers too, and they have a gang of life on them compaired to his..My LS is a 97, his is a 00.. I told his *** its time for B20Vtec..
Jota
Engine Machining & Assembly
13
Apr 10, 2016 03:02 AM
zstanglin
Honda Civic (2001 - 2005)
Jul 12, 2013 01:47 PM
Alex Goodman
Jan 29, 2005 11:45 AM
fe519
Jul 3, 2003 07:03 AM
goforbroke
May 14, 2002 12:48 AM
