Arias Ring Gap, 2nd comp rin too big?
Old Nov 6, 2005 | 02:55 PM
93turbo16's Avatar
Default Arias Ring Gap, 2nd comp ring too big?
Well I got around to putting together my motor today and come to find out that the ring gap on the second compression ring is about 29 instead of around 22 where I wanted it. My top compression ring is at 20. How much will this hurt? I was thinking about just getting a new set of rings.
Now some things that might effect this:
Block is a B16A2: The pistons are Arias 81.5mm and the rings are from arias.
The pistons have a coating on the skirt. I am thinking that the coating on the skirt has pushed the bore to be bigger than just the normal piston, hence my big ring clearance up top. The pistons were miced and then the block was bored.
The motor is going to be used in a drag car and will see a good bit of boost.
Any help is appreciated, just looking for some options/opinions.
HybridKOOP
Dec 5, 2011 10:53 PM
x2gold
May 16, 2006 05:10 PM
93turbo16
Nov 7, 2005 09:35 AM
siis2fast
Jun 7, 2005 03:52 AM
haggar
Aug 26, 2003 06:37 AM
