prelude rpm jump
my wifes car when accelerating under hard load was jumping earlier. you could watch the rpm gauge move eratically and you could feel it jump. i don't think it has anything to do with the timing belt because it has about 25xxx miles on a belt change.
it actually threw a ignition output code or something a couple of months ago. I reset it to see if it would throw it again. it is strange, awhile back it threw the atmospheric pressure code and never threw it again. what code did it give when your coil was going? was it showing the same symptoms i changed the plug wires awhile back and the coil had some green buildup on it does that mean it is going?
mine didnt throw any codes when my coil shot.. it just blew up... as far as the breeen buildup.. mine had nothing of the sort on it.. my blowin coil kinda bubbled uot on one side of it.. and was the only thing noticaley differeant than the good one i replaced it with.
no rev limiter kindof feel. i pulled the dis cap to check it and when on to the plugs and the number 1 plug wire wont attach to the spark plug kind of sounds like the problem to me.
spyderracing
Sep 30, 2004 05:59 PM
Mr. Softee
Sep 25, 2003 05:08 PM
accelerate, accelerated, acceleration, cars, change, eratically, gauge, h22, honda, jump, jumping, jumps, prelude, rpm, rpms, toyota
