how hard to take apart the entire dash???
Old Nov 6, 2005 | 12:36 PM
EF9 JAMS!!!'s Avatar
Default how hard to take apart the entire dash???
does anyone have any pics on how to take the entire dash out??? how long does it take???
Old Nov 6, 2005 | 12:41 PM
md88hfcrx's Avatar
Default Re: how hard to take apart the entire dash??? (hatch91JDM)
to completely disassemble every piece possible? HOURS? DAYS? depends all completely on your skills and efficiency.
Old Nov 6, 2005 | 05:34 PM
jdmcars.com's Avatar
Default Re: how hard to take apart the entire dash??? (md88hfcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md88hfcrx &raquo;</TD></TR><TR><TD CLASS="quote">to completely disassemble every piece possible? HOURS? DAYS? depends all completely on your skills and efficiency.</TD></TR></TABLE>
We can pull them out with in about 30 minutes. I have seen first timer take all day or even two days.
Sorry, no pictures of the removal though
Old Nov 6, 2005 | 05:37 PM
CoreyR's Avatar
Default Re: how hard to take apart the entire dash??? (jdmcars.com)
the first time it takes a long time cause of all the hidden bolts and clips that you dont know about or cant see. after that you know whats where and how to get to it.
Old Nov 7, 2005 | 02:12 PM
Default Re: how hard to take apart the entire dash??? (CoreyR)
i figured it out...pretty simple...
Old Nov 7, 2005 | 02:45 PM
Markb16a's Avatar
30 minutes to a hr depends on how many times u have done it already like there are like 5 or 6 bolts that holds the dash on 10 mm and taking the dash and gettting it over the steering wheel is kinda hard without breaking it but about a hr depends on like if u have a lot of stuff to the dash though
etc. cd player all that good stuff
its easy stuff
Old Nov 7, 2005 | 04:40 PM
STREETWERKZ's Avatar
Default Re: (Markb16a)
if you have to ask, its probably too hard for you.
took me maybe an hour to remove complete dash and heater core.
maybe another half an hour to cut out all the **** i didnt want, and another 15 minutes to plug it in, and bolt it up.
i'll post pics when i get off work of a completely gutted EF with gutted dash.
Modified by STREETWERKZ at 10:50 PM 11/7/2005
Old Nov 7, 2005 | 07:39 PM
mahatma's Avatar
Default Re: (STREETWERKZ)
Allocate a decent amount of time for it. I thought it was a pain in the dick.
And even after removing the steering wheel and lowering the column as much as possible without unbolting it, I still managed to crack the corner of the dash right by the VIN. It was awkward to remove.
Old Nov 7, 2005 | 09:51 PM
added my picture.
Old Nov 7, 2005 | 10:44 PM
Chico90hb's Avatar
does any one have a diagram of all the bolts to the dash cause im about to dash swap
Old Dec 18, 2005 | 07:09 PM
PA MATT's Avatar
Default Re: (Chico90hb)
bringin this back from the dead. Im tryin to disassemble my 88 crx si dash. I want to get the piece that works the window defroster off if possible or get access to the bottom. Is this possible? that piece was broke off by my friend when he picked it up. It seems to fit okay and seems like if i worked some superglue in there and put some jb weld or something underneath it would be either unnoticeable or very hard to tell. TIA
Old Dec 20, 2005 | 05:02 PM
PA MATT's Avatar
Default Re: (PA MATT)
anybody? I've taken apart just about every screw i can find. I can't seem to get any of the "hard" plastic pieces to seperate from the "softer" pieces...TIA
Old Dec 20, 2005 | 05:41 PM
Jonathan_ED3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">anybody? I've taken apart just about every screw i can find. I can't seem to get any of the "hard" plastic pieces to seperate from the "softer" pieces...TIA</TD></TR></TABLE>
...Because the entire dashboard is glued together AND also screwed together.
You won't be able to subdivide the dashboard without cutting it apart.
Old Dec 20, 2005 | 07:32 PM
PA MATT's Avatar
Default Re: (Jonathan_ED3)
lol, i wish somebody would have mentioned that in this thread. O well, guess ill just put it back together instead of cuttin everything up
Old Dec 20, 2005 | 07:47 PM
Well, maybe I should clarify.
MOST of the dash won't seperate.
I think I know what area you're talking about, but I can't be certain.
Any way you can take a picture of it?
Old Dec 20, 2005 | 08:06 PM
PA MATT's Avatar
yeh, i can do that...Lemme find my digi cam, throw some batteries in and snap a few. It'll be morning by time i do it though. Thanks for the help
Old Dec 30, 2005 | 09:04 AM
KansasKev's Avatar
Bump
liketofry
Honda Civic (2006 - 2015)
Oct 13, 2006 08:08 AM
acurar0ss
Dec 12, 2005 04:35 PM
mountaindewguy
Oct 24, 2005 08:04 PM
Brw
Jul 1, 2004 11:47 AM
Coaster
Nov 30, 2001 11:53 PM
