quick injector question
working on a 90 civic dx sedan. I'm wondering if anyone knows what the resistance is supposed to be on the injectors. I searched but didnt find anything. Any help is appreciated.
Thanks in advance
Thanks in advance
some test 2 ohms and some test 6-10 ohms. i think the 2 ohms are for d-series and 6-10 are b-series. should be in a haynes or helms manual if you have one.
didnt mention it before but it is a 1.5 dpfi. just checked it and the top injector is at 1.3 ohms and the bottom one is at 8.3 ohms...
the car starts and runs but only on 2 cyls, the main relay is good. i have spark at all 4 and good compression. still no cel. any other thought as to what it could be?
I'm 'guessing' that the injector at 8.3 ohms is bad....
Umm replace it if ya can.
Or atleast swap them around if ya can and see if that makes the other 2 cylinders run and not the other two... catch the drift? (you can tell by which spark plugs get all fuel fouled edit: or which 2 get burnt to a silvery/grey sheen)
