Welding a cracked tranny case ?s
Old Nov 6, 2005 | 10:23 AM
98se-rTurbo's Avatar
Default Welding a cracked tranny case ?s
Well I managed to crack my tranny case last week.I purchased another one from a member on another forum and it to was cracked! so anyway I'm thinking about having the hairline cracked welded but had a about how long it will last or is it even worth it? I really don't have extra money to buy another transmission.
Thanks.
Old Nov 6, 2005 | 12:05 PM
180MPHGUY's Avatar
As long as its cleaned really good and pre heated before welding and the welder knows what hes doing, it should last for a long time.
Old Nov 6, 2005 | 05:27 PM
JK_Motorsports's Avatar
Default Re: Welding a cracked tranny case ?s (98se-rTurbo)
I snapped the whole rear mount off mine on my ZC. I dismantelled the entire Tranny, Degreased the **** out of it, took it to my neighbor (the BEST TIG Welder I have ever seen) and he welded it back together. Nothing like a 3" chunk of aluminum coming off with 3 bolt holes in it.
2 years, Hard Launches on a 6puck Unsprung Clutch, no problems.
Old Nov 6, 2005 | 09:40 PM
L-CON1's Avatar
Default Re: Welding a cracked tranny case ?s (bumblezc)
i do it all the time for a local swap shop!
Old Nov 6, 2005 | 09:51 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Welding a cracked tranny case ?s (L-CON1)
have we established what grade of aluminum or tranny cases are? i just assumed it was sort of a "pot metal" mix
Old Nov 6, 2005 | 11:46 PM
k24em2's Avatar
Default Re: Welding a cracked tranny case ?s (wantboost)
Its weldable, but its dirty. Cleaning is key.
Old Nov 6, 2005 | 11:49 PM
DohcVtecCrx's Avatar
Default Re: Welding a cracked tranny case ?s (k24em2)
I had the same question not long ago:
https://honda-tech.com/zerothread?id=1406136
Old Nov 7, 2005 | 06:19 AM
Default Re: Welding a cracked tranny case ?s (DohcVtecCrx)
Is the tranny the same material as the block?
This is what I would like to know. Want to determine the Expansion Rate of the outer block.
creepass
Jul 4, 2009 05:13 PM
sp00ledbseries
Welding / Fabrication
May 7, 2009 12:20 PM
FormulaGSR
Jul 12, 2005 08:12 PM
egamjah
Jun 9, 2005 09:25 PM
oreozzz
19
Jan 5, 2005 09:48 PM
