timing... advance or RETARDED (me).
Old Mar 9, 2002 | 01:22 PM
neumonik's Avatar
Default timing... advance or RETARDED (me).
Just want to make sure before I go doing it.... does retarding your timing lessen your chace of detinating? Or is it the other way around?
Thanks!
Old Mar 9, 2002 | 01:35 PM
jt-sport's Avatar
Default Re: timing... advance or RETARDED (me). (neumonik)
yeah, if u got ur engine knocking then retard it.
but it'll reduce the porfomance if it. as far as this ,i've found that 32 degree (at total timing advance by vacum) give the best peak Hp
Old Mar 10, 2002 | 05:42 AM
neumonik's Avatar
Default Re: timing... advance or RETARDED (jt-sport)
cool, thanks for the info. I would rather temporaraly retard the timing and not kill my engine then worry about the power for now!
Thanks again!
Old Mar 10, 2002 | 06:51 AM
jrsc teg's Avatar
New User
Default Re: timing... advance or RETARDED (neumonik)
You should only retard it if you have FI..
Old Mar 10, 2002 | 04:41 PM
tinkerbell's Avatar
Default Re: timing... advance or RETARDED (jrsc teg)
on a JDM B16A on the crank pully there are 3 little spots that are close together that you point the timing light at - what do they mean?
i have been *assuming* that the one in the middle is 16' BTDC and the one closest to the rear is 14' BTDC and the one furtherest to the front is 18' BTDC...
is this true?
i have also assumed that 18' BTDC is advanced.
is this true?
i have used this method to "advance" my static timing for more NA power...
t..
sikek1
Apr 28, 2008 05:49 AM
mortificationrock
Jul 10, 2007 04:26 PM
kixcrx
Nov 10, 2006 10:33 AM
gsrguy
Feb 7, 2004 02:10 PM
