buying a 94 gsr, couple questions
my current car is going to get totaled out and i have my eyes on a 94 gsr. i was wondering if there are any things i should be looking out for, or any common mechanical or cosmetic problems that i will be looking at in the future. also could you guys give me some links to lips kits that are clean and cheap, the car needs them badly.
thx for any help
thx for any help
Guest
Posts: n/a
94-95 are good depends how much money u spend.
$4500 to $5000 depending on the miles and the title maybe a little bit lower if its a sav.
u should test drive the sh*t out of it , hit vtec hard and see if anything is wrong with it.
check for oil leaks and etc..
hope this helps good luck on buying one
craigslist.com is a good place to purchase a car in cars & trucks
for the lip u can check ebay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2uy »</TD></TR><TR><TD CLASS="quote">94-95 are good depends how much money u spend.
drive the car hard and make sure the fans come on when you stop. check underneath the car for leaks. look at all the guages when you're driving to make sure they all work.
i'm not trying to sound like an *** but just take your time and look at everything twice. it's always the small things that people forget to look over...
</TD></TR></TABLE>drive the car hard and make sure the fans come on when you stop. check underneath the car for leaks. look at all the guages when you're driving to make sure they all work.
