Accord shakes when i put Brakes
Old Nov 6, 2005 | 08:45 AM
MtbikingKing's Avatar
Default Accord shakes when i put Brakes
My 97' accord starts to shake slightly when i put on the brakes. Before my mechanic replaced the brakes themselves and that fixed the problem for a bit, but it came back again. He says he doesnt know whats wrong and how to REALLY fix it.
Does someone know or had the same problem and fixed it??
Should i go to a Honda dealer??
If someone did have the same problem i'd like to know so i can tell the mech's what it might be instead of them looking around and charging me a fortune in labor costs.
~Thx
Old Nov 6, 2005 | 08:54 AM
Accord Hot Rod's Avatar
Default Re: Accord shakes when i put Brakes (MtbikingKing)
Ive got a 96 coupe with the same issue, but its only at expressway speeds. Ive got 17in rims tho, I think the problem is the wheels/tires arent balanced correctly. I would recommend trying that.
Old Nov 6, 2005 | 09:32 AM
P_Adams's Avatar
Your rotors have warped. A condition of several causes; but the most common is the uneven tightening of the lug nuts.
Your one course of action has two ways to accomplish it.
1) remachine the rotors off the car or
2) regrind the rotors on the car
if they've been remachined prior, they should be checked for thickness. If they're below spec they will require replacing.
P
Edited for stupid Spelling trick
Modified by P_Adams at 12:10 AM 11/7/2005
Old Nov 6, 2005 | 09:33 AM
deserthonda's Avatar
if it shakes when braking u most likely have warped rotors ,,,,,,,,,, go on a clear road, go to speed where problem normally occurs at, but instaed of braking via the pedal just use the e-brake ,,if it shakes u could have rear rotors ( drums ) warped.....if it is ok by using e-brake, than i would have the frt rotors checked for warpage ,,they could be machined if thick enough if not u might have to install new rotors,, Also chk for any loose suspension parts,, ( inner + outer tie rods ) ball joints, etc etc ...
Old Nov 6, 2005 | 10:00 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Accord shakes when i put Brakes (deserthonda)
yup, rotors
ohplezz
Feb 16, 2010 03:33 PM
mansif
Jan 2, 2009 03:35 AM
jipr
Feb 26, 2005 01:00 PM
nygunrunners
Nov 2, 2004 03:36 PM
Crazykobe
Aug 8, 2004 09:18 AM
