Clutch Pedal (searched!!)
Old Nov 6, 2005 | 08:38 AM
Coltmorris's Avatar
Default Clutch Pedal (searched!!)
Hey I have a 91 Dx with a JDM D16a swap. The car was auto and was switched to manual as was the motor. My clutch pedal is very strange as is the cable. Clutch feels very slow and very stiff--like it doesnt wanna come back up. I tried adjusting it but it only made things feel worse. The spring on the pedal isnt a normal spring its one of those circular springs (will post pics if needed) The cable seems too long and its not secured as there is no bracket on the valve cover. My question is: What can I do to get this clutch normal again? Would simply replacing and securing the cable be enough? Or should I change the entire pedal assembly as well. Thanks very much!
Old Nov 6, 2005 | 09:09 AM
bagpipe goatee's Avatar
i'd start with replacing the cable. or, if you can, borrow it from a friend to see if that's the problem.
also, make sure your pedal cluster isn't broken or cracked, and that it moves freely with the cable disconnected.
good luck.
Old Nov 6, 2005 | 09:17 AM
Coltmorris's Avatar
Default Re: (bagpipe goatee)
ok yea that sounds like a good idea. i didnt think about the cluster idea--thanks! Im confused about my spring though and why its different than the normal setups
Rand The Man
Jul 24, 2010 07:09 PM
buugiewuugie
Apr 16, 2008 03:35 PM
4drDA
Aug 29, 2005 01:11 PM
GreenMachineRex
May 4, 2004 06:22 AM
