are input shaft's interchangeable
Old Mar 9, 2002 | 12:50 PM
civbeater90's Avatar
Default are input shaft's interchangeable
can you interchange the input shafts between 88-89.i know they have differnet spline counts that' why i want to change to a 89 so i can use the bigger clutch,and also to have more clutch options.
Old Mar 9, 2002 | 01:37 PM
AwwsChwA's Avatar
Default Re: are input shaft's interchangeable (civbeater90)
yes, all of the 1989-1991 d-series input shafts are interchangeable. The 1988's have a different spline pattern. I haven't researched the b-series trannies, but im pretty much positive that those are also interchangeable for any b18, b16, etc etc.
Old Mar 9, 2002 | 03:41 PM
Default Re: are input shaft's interchangeable (AwwsChwA)
i know the 88 are differnt.i'm trying to take the 88 shaft out and put in a 90 is this possible?
[Modified by civbeater90, 12:42 AM 3/10/2002]
Old Mar 9, 2002 | 06:24 PM
AbaZ's Avatar
I am almost a 100% postive you can interchange the input shafts of the L-3 trannys, I have a 89 SI shaft on my 90dx tranny.
Jeff
Old Mar 9, 2002 | 08:38 PM
Default Re: are input shaft's interchangeable (AbaZ)
thanks abaz-i almost postive they will work also i have checked all the part numbers of the poarts that go one them such as the bearings and gears and what not.so it should work.i'm gonna try it and i will post the results.
Old Mar 9, 2002 | 08:41 PM
Mugen Dom's Avatar
the 88 maybe different do to the 21 sline tranny i dunno if teh input shaft would be 21 sline but u may run into problems
rice a roni
13
Apr 14, 2006 01:00 PM
scratchline20
Oct 28, 2003 02:06 PM
Attoir
Oct 5, 2003 07:35 AM
Bravenrace
Feb 28, 2003 08:56 AM
