Engine builders! I have some???????s
Old Nov 6, 2005 | 06:57 AM
wishingiam's Avatar
Default Engine builders! I have some???????s
I have a US typer block and the piston rings are fried, I've found a site called goodson.com and would like to know what's your opinion on their honing kits? Which one do I get? I just want to clean up the cylinder walls without stripping the entire block.
I also would like to run the stock rods, but run a little higher compression, how can I accomplish this? Please recommend a piston. Or if it's possible to order the pistons and rods already assembled.
I am new to building motors, and have absolutely no money to have it built, I have done simple things like install stock valves, and valve springs, and have been reading up on plastigauge, but would like to keep the build as cost effective as possible, so stock rods and bearing codes would apply to keep it simple.
This is for a street car, and I'm gonna run a stock ctr head, with the possibility of getting a mild cam later.
If you've read this far Thanks for bearing with me
Any and all comments welcome
Old Nov 6, 2005 | 08:18 AM
b19coupe's Avatar
Default Re: Engine builders! I have some???????s (phuckyou)
Have the block professionally machined. Go to 81.25mm on the bore and use new OEM pistons and rings. Or you could go 81.5mm and use Topline pistons for about $130. You could try to get by with new rings on your old pistons and just hone the block, but chances are you will regret it later.
Old Nov 6, 2005 | 09:15 AM
hi-Powered's Avatar
Default Re: Engine builders! I have some???????s (b19coupe)
who does bore/honing work in the OC area?
and how much?..
Old Nov 6, 2005 | 09:42 AM
b19coupe's Avatar
Default Re: Engine builders! I have some???????s (hi-Powered)
Bensons Performance Machine.
~100-150.
Old Nov 6, 2005 | 08:17 PM
wishingiam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Have the block professionally machined. Go to 81.25mm on the bore and use new OEM pistons and rings. Or you could go 81.5mm and use Topline pistons for about $130. You could try to get by with new rings on your old pistons and just hone the block, but chances are you will regret it later.</TD></TR></TABLE>
I'm trying to cut costs as much as possible, so if it's within reach to hone it myself I would like to, the cylinder walls look ok so just needs a quick hone. The only things I want to change would be the pistons,rings, and a big maybe to rods (I prefer oem parts). You know of any other place that might carry a hone "kit"?
TIA
Old Nov 6, 2005 | 08:40 PM
1heavy4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hi-Powered &raquo;</TD></TR><TR><TD CLASS="quote">who does bore/honing work in the OC area?
and how much?..</TD></TR></TABLE>
Bensons
Old Nov 6, 2005 | 09:18 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phuckyou &raquo;</TD></TR><TR><TD CLASS="quote">
TIA </TD></TR></TABLE>
please just take the block & have it done by a pro don't try that drill hone kit please that **** sucks
funintheteg3
Mar 1, 2010 06:49 AM
hondaluver12
Jan 26, 2009 04:32 PM
spunautosports
Dec 24, 2006 07:09 PM
Power Rev Racing
Oct 23, 2004 12:48 PM
N1Spec
Oct 20, 2002 08:06 PM
