d16a1 pistons into d16y8 compression question
Old Nov 6, 2005 | 12:20 AM
d16y8EL's Avatar
Default d16a1 pistons into d16y8 compression question
ok, the stock compression of a d16y8 is 9:1 with the d16a1 pistons the compression is 13:1. Now if i were to switch the pistons in my d16y8 with the a1's would the gains be noticable with the compression increase?
i have i/h/e at the moment on my setup, but thats negligable.
If i were to go ahead and do this, what would the pro's/con's of doing this as a N/A setup start?
would it be wise to get arp headstuds for the increased compression? change the headgasket thickness, etc.??
Old Nov 6, 2005 | 10:44 AM
d16y8EL's Avatar
bump.
Old Nov 6, 2005 | 02:19 PM
d16y8EL's Avatar
someone must know
Old Nov 6, 2005 | 02:26 PM
jonbouy's Avatar
Default Re: (d16y8EL)
you would get a power increase but your guna need bigger injectors more fuel, as far as the head gasket goes fitting a thicker head gasket would only lower the compression again maybe fitted a higher performance one of the same thickness
Old Nov 6, 2005 | 05:33 PM
CivicEX13's Avatar
are you sure this would work for sure that it increases the compression that much? just seems a little too good to be true to me...but idk
Old Nov 7, 2005 | 12:40 AM
d16y8EL's Avatar
i was going by the compression calculator found here. http://www.c-speedracing.com/h...c.php
Old Nov 7, 2005 | 03:30 AM
sohc_boy's Avatar
stock injectors should be fine. compression will make the engine much more responsive, there have been quite a few board members that have done exactly what you have in mind (ask tom b18c? don't remember the rest of his member name). i know builthatch made around 160 at the wheels with a similar build. obviously your going to want a bigger cam to match the compression and maybe further along down the road some porting.
Old Nov 7, 2005 | 05:00 PM
CivicEX13's Avatar
well hey that would be awsome let me know if you find anythign else out about this causei wouldnt mind doing this
d16y8EL
Nov 7, 2005 12:42 AM
elevatethis
Dec 30, 2003 12:24 PM
quicksol95
Nov 20, 2003 06:46 PM
