96-00 civic rear struts/shocks
im getting new shocks/struts for the rear of my car
its a DD so i dont want anything fancy just something comfortable
i have no-name coilovers and i want to know which shock/strut would be most comfortable
thanks for any help
set up #1
http://www.slickcar.com/produc...=2563
setup #2
http://www.slickcar.com/produc...=2470
thanks for any help
set up #1
setup #2
I had suspension technique springs on stock shocks, and then I got omni power sport coilovers, and now I am putting together koni/ground control.
The full coilovers are a harsh ride, unless you get the expensive ones with progressive springs. I'm looking forward to the adjustability of the koni.s
If you want comfortable either go with a custom spring rate or go with what a lot of people run which is either the eibach pro-kit or sportlines (very soft yet firm ride and nice lowered stance) or some of the h&r springs.
As for the shocks kyb's are nice but if you want adjustability go with the agx's and set them soft for daily driving or harder/stiffer for any track use. The gr2's are basically a stock replacement. Some will also chime in and say the koni yellows are a good adjustable shock, which they are they just tend to cost a little more than the agx's.
With those no-name coilovers your ride will be harsh with almost whatever shock you choose.
