choiboi's sfwd 95% finished.
Old Nov 5, 2005 | 09:00 PM
choiboiracing's Avatar
Default choiboi's sfwd 95% finished.
alright guys i finally got this thing going. it took over 2 years and many many paychecks.... i probably wont be able to make it to palmdale cuz the money for the axles and boost controller is not yet available unless some one can hook a racer out? thanks todd @ full-race ( u guys are the ****), tom@camp1320 my korean bros, bubba & beto(do it dyno) i need another dyno hook up, tony1 i need help setting boost???? very complicated.... will i need some car stuff (exospeed).
hopefully i can finally write to some companies to actually get something for cheap or ever luckier= FREE....
Old Nov 5, 2005 | 09:05 PM
Default Re: choiboi's sfwd 95% finished. (choiboiracing)
btw, we made around 460 hp and like 25x ft tq at 12-14 psi... i need Bubba to make a link cuz it was like 2 AM when we were finished.
Old Nov 5, 2005 | 09:25 PM
paulzy's Avatar
nice...where's the breakdown?
Old Nov 5, 2005 | 09:52 PM
andysila's Avatar
choiboi built
Old Nov 5, 2005 | 10:16 PM
onlinehost's Avatar
Default Re: choiboi's sfwd 95% finished. (andysila)
bump man i saw your car at bubbas i was on the dyno with my green eg when you were there
Old Nov 6, 2005 | 12:04 AM
jarel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila &raquo;</TD></TR><TR><TD CLASS="quote">choiboi built </TD></TR></TABLE>
hell ya....great job garry can't wait to see this car up and running at the track
jarel
Old Nov 6, 2005 | 01:32 AM
Alaniz technologies gsr head w/ ti retainers, dual valve springs, 1mm bigger valves, 84 mm w/ arias pistons, crower rods, honda bearings, crank, quaife lsd, exedy twin disc, 1k cc injectors, full race top mount w/ full race turbo, 44mm tial wastegate, msd dig 6,
Old Nov 6, 2005 | 01:36 AM
andysila's Avatar
motec power
Old Nov 6, 2005 | 04:12 AM
eg2.0dart's Avatar
Default Re: choiboi's sfwd 95% finished. (jarel)
man great set-up and numbers for low boost, i was looking at your pictures u post, and i might see something wrong, fuel regulator and 90deg angle. there alot of stress on that fitting which may cause it to crack, i had my reg same position and a couple of months down the road she cracked and fuel went everywhere, from what i can see there no bracket supporting that regulator. just trying to help u out man, u spent alot of money on this build. good luck. Sam
Old Nov 6, 2005 | 04:16 AM
DaveF's Avatar
Default Re: choiboi's sfwd 95% finished. (eg2.0dart)
where did you get that radiator ???
Old Nov 6, 2005 | 05:14 AM
95GLX's Avatar
looks like a 250 atv radiator!!!!!
Old Nov 6, 2005 | 05:20 AM
gtturborex's Avatar
Default Re: (95GLX)
Nice setup! Good luck
Old Nov 6, 2005 | 05:41 AM
11SEC CIV's Avatar
Default Re: (gtturborex)
nice set up, good luck in the upcoming season
what is your suspension set up?
Old Nov 6, 2005 | 08:58 AM
tony1's Avatar
Default Re: (12SEC CIV)
Looks good Gary! EG2.0 is right about the regulator, i've seen it happen as well. Move it to the firewall and run a line from the rail to the reg.
Give me a call and i'll help you setup the boost controller.
Old Nov 6, 2005 | 09:07 AM
hi-Powered's Avatar
that's pimp....good luck.
Old Nov 6, 2005 | 09:09 AM
.nate's Avatar
Car looks nice man! You should really at least have axle ends in your hubs... It's hard on the bearings just sitting like that.
Old Nov 6, 2005 | 09:19 AM
rhd's Avatar
rhd
wow at rad hoses....wow
and what kind of power are you shooting for, with the stock ignition/digital 6? and any reason why you dind't go COP? I'm just wondering cause i've seen a LOOOOOOOOT of digital 6's fail.
Old Nov 6, 2005 | 10:49 AM
JdmEKCivic's Avatar
Default Re: (rhd)
very nice setup good luck with everything
Old Nov 6, 2005 | 10:55 AM
andysila's Avatar
Default Re: (tony1)
the car looks/sounds sick in person.
Tony, help gary with the boost controller so we can see some high boost #'s
Old Nov 6, 2005 | 11:36 AM
fknfast's Avatar
Default Re: (andysila)
very very HAWT!!!!
looks sick bro
Old Nov 6, 2005 | 12:24 PM
thats craze cuz 2 other people told me that too... about the 90 degree.. that thing costs more than my motec, oh well it loooked nice tho. the radiator is a custom c&r 10 inches by 16 inches. i believe dtrturbo has one also.... it is nice cuz the car does run cooler when engine is warmed up. as far as the -20 fittings, i dont know if that is necessasry... i think the lines cost more than my radiator(?).
as far as suspension, i have old school ground control with koni yellows.... 600 in the fron and 1xxx in the rear... i am experimenting with some different shock springs (k) and see what happens....
Old Nov 6, 2005 | 03:11 PM
Turbocivic94's Avatar
Sick *** setup
Old Nov 6, 2005 | 03:24 PM
0554's Avatar
nice work man. good lord that thing looks like an airplane inside with all those gauges and switches. lol
Old Nov 6, 2005 | 03:36 PM
Default Re: choiboi's sfwd 95% finished. (itr554)
guys its a 90% chance i am going to palmdale.... if this company comes through then i am in.... i will have my 25psi dyno up for sure next week. thanks bubba for the hook up. its weird but one of my dreams is to have a parachute on a race car.... i hope soooo....
btw, if it wasnt for this thread then i would have never been able to get as far as I did. i am one of those "i like to do most things myself." i was one of those sylmar/ontario/glenoaks/saticoy racer but i will kill myself if i ever get this baby impounded (previously known as vivid racing/coupe).
anyone know where i can get the cheapest Drive Shaft Shope stage 5 axles? this is my first favor i ask on honda-tech.
Old Nov 6, 2005 | 04:14 PM
boostfeen's Avatar
lookin good.
