What causes flywheel bolts to loosen?
Old Nov 5, 2005 | 08:52 PM
flip1199's Avatar
Default What causes flywheel bolts to loosen?
Just got done doing a clutch job on a b18c1 in a 99 si with a b16 tranny. when i pulled the original clutch off i noticed 2 of the bolts had loosened up and backed out and was grinding against the clutch, and 4 of the other bolts were hand tight. i reinstalled the resurfaced flywheel and torqued it down to 80 lbs and reinstalled everything else. the owner went on a lil 30 min drive and called me back saying it's making the grinding sound that it did with the old clutch, so i'm guessing the flywheel bolts backed out again. should i use some locktite on them and retorque them to 80lbs again?
Old Nov 5, 2005 | 10:53 PM
Cuda70's Avatar
Default Re: What causes flywheel bolts to loosen? (flip1199)
It doesnt hurt to use locktite. I always do in all my clutch builds.
Old Nov 6, 2005 | 04:55 AM
NJIN BUILDR's Avatar
Default Re: What causes flywheel bolts to loosen? (Cuda70)
Yes.Definitely locktite them.
Glenn
Old Nov 6, 2005 | 07:08 AM
builthatch's Avatar
MiG-21 superfan
Default Re: What causes flywheel bolts to loosen? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Yes.Definitely locktite them.
Glenn</TD></TR></TABLE>
always...
i've seen many a f'd up clutch job due to no loctite for the flywheel or pressure plate bolts.
Old Nov 6, 2005 | 05:42 PM
sickerhatch's Avatar
Default Re: What causes flywheel bolts to loosen? (builthatch)
Ive never used lock tite on fly wheel bolts and I've never had a problem.
Make sure you torque them correctly.
Old Nov 6, 2005 | 06:35 PM
slomofo's Avatar
GDD Member
I never use loctite and had this problem ONCE. I pulled the clutch three times and on the last time I noticed the flywheel bolts were stamped AT and just then I realized, flexplates are so much thinner than flywheels so the bolts were too short.
Old Nov 7, 2005 | 11:07 AM
WhiteNess's Avatar
Default Re: (slomofo)
always use locktite on those bolts, it can cause all kinds of trouble when they come out, and tourqe them to 84lbs....also go in incriments of 20......like 20lbs, 40lbs,60lbs, 84lbs
cletus11
Jan 7, 2012 12:07 PM
fwdlooser93eg
Jul 24, 2006 06:52 PM
integraautox
Apr 4, 2003 08:36 AM
integraautox
Jan 23, 2003 01:14 PM
4doorH22
Mar 12, 2002 06:31 PM
