Help with the Bubble-Back...
Old Nov 5, 2005 | 08:07 PM
5Point7Liter's Avatar
Default Help with the Bubble-Back...
Cruising around town today I pull up next to a Kia Sorento with exhaust and rims. I put it in neutral and rev up the exhaust, he does the same. The light turns green....I take off, I quick shift up to second, then to Drive but miss the shift and go into neutral and i bounce off the rev limiter. My car starts to die down a little and no longer feels "peppy" at all. My Vtak is no longer working and my service soon light jumps on. I hook up my PC and do a system diagnostics and it says that power was decreased to 50% due to excess heat to thermostat and low blinker fluid. I have a new thermo on order from Japan, but the blinker fluid is what has me confused. I picked up the good brand from the local Autozone today ("Bri-Blink*9" brand), 3 quarts, but can't seem to find it under the hood. I looked past and around the coolant tank, oil pan, engine block, muffler, and even the Vtak purifier screen....and found nothing! Any help here? It's a 1992 Civic. This is my only car, so need to fix this ASAP! Thanks in advance!
Old Nov 5, 2005 | 08:16 PM
92BluEH-3's Avatar
lulz
????????? is this a serious question. well im gunna answer it anyway. (put flame suit on guy) first you need a manual. 2nd there is no blinker fluid.3rd autos arnt made to shift. hope that helps
Old Nov 5, 2005 | 09:23 PM
boosted civic 2k6's Avatar
Default Re: Help with the Bubble-Back... (5Point7Liter)
def right. flame suite buddy
Old Nov 5, 2005 | 09:24 PM
dewoine's Avatar
Default Re: Help with the Bubble-Back... (jxmac2o6)
omg this has to be a joke!!
Old Nov 5, 2005 | 09:26 PM
UrbanEh's Avatar
Umm.... nice try
Old Nov 5, 2005 | 10:15 PM
jdm_ekcivic's Avatar
Lay off the crack buddy.
Old Nov 5, 2005 | 10:21 PM
Jorsher's Avatar
HAHAHAHHAHAHAHAHAH not really. Lame tho
Old Nov 5, 2005 | 10:27 PM
Heylookits shawn's Avatar
you could try replacing the wombulator shaft
or maybe the muffler bearings are going out.
you say you checked the vt4k purifier, but did you try the flux capacitor?
Old Nov 5, 2005 | 10:34 PM
97spooncivic's Avatar
Default Re: Help with the Bubble-Back... (Heylookits shawn)
no, you poor the blinker fluid in your intake. you can even get a 5 hp gain. then you rub motor oil on your rotors so you stop slower wich helps you go faster down the track
nub the oil in the intake was better. nice try
Old Nov 5, 2005 | 10:37 PM
Cuda70's Avatar
Default Re: Help with the Bubble-Back... (97spooncivic)
If you look just below your intake you can find a screw that you have to remove to put this fluid in...
However, you will need left hand metric screwdrivers to remove the screw.
Old Nov 5, 2005 | 10:53 PM
n8byte's Avatar
If you rub your engine in cheetah blood it will go way faster than any blinker fluid could do ya
Old Nov 5, 2005 | 11:06 PM
MasterShake's Avatar
Default Re: Help with the Bubble-Back... (n8byte)
OMG! I mean...Whoa...like...umm...what...hmm...(sigh)
is this a bannable offence?
________
Mflb
Old Nov 5, 2005 | 11:12 PM
hapexamendios 2.0's Avatar
R.I.P.
wow lol
Old Nov 6, 2005 | 01:25 PM
92BluEH-3's Avatar
lulz
yall forgot to take off the valve cover and put the sand from the Sahara Desert in there. you get more power from that than you will any turbo
Old Nov 6, 2005 | 01:43 PM
peacexisxfree's Avatar
Default Re: (92'BluV-tecHatch)
oil in the intake was definitely better. a kia sorrento? yeah, nice try...
Old Nov 6, 2005 | 02:01 PM
Default Re: (peacexisxfree)
Why is this still here? I reported this to a mod a while ago.
Old Nov 7, 2005 | 07:08 AM
92BluEH-3's Avatar
lulz
yea this should be taken off now!
Old Nov 7, 2005 | 07:24 AM
Slow EJ8's Avatar
lol at all the sugestions in this thread... oh yea and to the OP- your not funny
reported too for good measure
Old Nov 7, 2005 | 08:10 AM
Specail Ed's Avatar
Default Re: (Slow EJ8)
Just look at his name, it says it all. He must have got spanked by a 4 banger and now wants to take it out on the rest of us. What a simp.
carcrazy746713
Acura TL, RL & ZDX
Jun 8, 2017 09:44 AM
sohcvtec97
14
Apr 20, 2005 12:35 AM
Das Nuge
Oct 31, 2004 09:15 PM
