How to tell when halfshaft is all the way in the tranny
Old Nov 5, 2005 | 04:29 PM
Steve91's Avatar
Default How to tell when halfshaft is all the way in the tranny
Is there normally any space between the flat face of the CV housings and the tranny? It seems no matter how much I fuss with the halfshaft install, there is still a 1/8" gap between the halfshaft and the trans housing. Is that normal? BTW this is on a D16a6
Old Nov 5, 2005 | 08:32 PM
iTe4LIFe's Avatar
yea it seem's a little wierd..... if the seals on the trans are installed properly and you slipped the shaft in without any probs... your good to go. my 88 std hatch is like that and i've seen that on b18's / acuras... as long as everything went it with ease you should be good.
Old Nov 5, 2005 | 08:43 PM
havok hybrid's Avatar
Default Re: (islandtechengineers)
d16a6? are you using a ZC haft shaft??? if so.. as long as the half shaft bolts to the motor and the whole line up . its in the right spot
Old Nov 5, 2005 | 09:39 PM
Steve91's Avatar
Default Re: (havok hybrid)
Its an A6 with stock A6 shafts.
94 EG GSR
Aug 14, 2009 09:28 AM
1baddcivicsi
Jun 19, 2009 08:02 PM
Monkeyz1
Jan 21, 2009 06:56 AM
93sivtec
Nov 19, 2007 02:11 PM
Gir
11
Nov 11, 2004 08:14 AM
