Where Did You Mount Your Breather Kits??(Pics Please)
Old Nov 5, 2005 | 03:51 PM
Touch's Avatar
Default Where Did You Mount Your Breather Kits??(Pics Please)
as the topic states... I was looking to mount mine over by the battery, but don't see how it will fit with the wire harness right there as well.
Thanks in advance.
Old Nov 5, 2005 | 06:29 PM
sleepycivichb's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (Touch)
https://honda-tech.com/zerothread?id=1393057
Looks good i.m.o. and i'm doing the same setup.
Old Nov 6, 2005 | 02:02 AM
Pondus's Avatar
Here's my setup, Endyn Breather kit :
Old Nov 6, 2005 | 06:22 AM
Touch's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (Pondus)
yeah, that seems to be the best place to put it. do i have to drill holes, or are they already there behind the wire harness?
Old Nov 6, 2005 | 12:30 PM
Pondus's Avatar
I drilled 2 holes and inserted a couple of rivet nuts to thread the bolts into.
Old Nov 6, 2005 | 04:03 PM
DEMNTD1's Avatar
I believe the bracket that comes with the Endyn kit can bolt up to the the bracket that holds up part of the engine harness on the side of the shock tower.
Old Nov 6, 2005 | 04:57 PM
onepoint6i's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (DEMNTD1)
theres absolutley nowhere to mount it on an EF with all emissions's etc except right in front of the charcoal canister...
Old Nov 7, 2005 | 05:15 AM
kay_animation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch &raquo;</TD></TR><TR><TD CLASS="quote">yeah, that seems to be the best place to put it. do i have to drill holes, or are they already there behind the wire harness?</TD></TR></TABLE>
Never drill
It comes with these plus: (endyn plugs though, these are honda ones, but they look the same)
If you look in the back of your block, there are 2 hex caps that are there, just unscrew those and put the hose versions in as seen above.
More on DIY version here: https://honda-tech.com/zerothread?id=1199935
So, it should look like this:
I'm going to hook mine up like this:
Except I'm just using one system
Old Nov 7, 2005 | 07:25 AM
Pondus's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (kay_animation)
Endyn supplies the exact same fittings in the kit, and on my ITR i had to drill 2 holes in the shock tower to mount the can, otherwise if using the one hole already there it was in the way of both the harness bracket and the strut bar.
Old Nov 7, 2005 | 07:56 PM
Touch's Avatar
yeah. kay, I am talking about the canister.
Old Dec 20, 2005 | 02:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
i know this is an old thread, and i am not all motor, but for people looking for info i think it will help.
Old Dec 20, 2005 | 02:59 PM
freakin's Avatar
Any DA's? I can't find anywhere to mount mine. I have a huge ABS module on the passenger side around the firewall. I'm out of ideas, so I think I'm going have to buy a different tank, more flat/wider design.
Old Dec 20, 2005 | 03:54 PM
hybrid_KJ's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (freakin)
On a DA if you are running an edlebrock mani you can mount it behind the manifold on the firewall.
On eg/ek/dc I weld a 5 by 4 inch plate to the battery tray and weld in two gussets and then drill some holes and bolt it up. It sits between the battery and fuel filter.
Old Dec 20, 2005 | 03:56 PM
ALLMOTOR18's Avatar
i mounted mine between the battery and the fuel filter...
Old Dec 20, 2005 | 05:39 PM
Da9teggy92's Avatar
is this breather for the oil? if so what are the benifits from it. and what does it do?
Old Dec 20, 2005 | 06:21 PM
riceball777's Avatar
please also post where you are running the hoses to
Old Dec 21, 2005 | 07:27 AM
Mr. Badwrench
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">please also post where you are running the hoses to </TD></TR></TABLE>
the two block fittings on the back of the block.
Old Dec 21, 2005 | 09:46 AM
dc-lefty's Avatar
anybody running any other breather kits other than endyn ?
Old Dec 21, 2005 | 11:59 AM
young noob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay_animation &raquo;</TD></TR><TR><TD CLASS="quote">
Never drill
Except I'm just using one system </TD></TR></TABLE>
is that a cut up trash-can/head deflector, i was thinking about doing the same thing with just aluminum, and then laying carbon fiber off it, do you notice any gains on the butt dyno, or have you actually dynoed the heat deflector
sorry for thread-jacking
Old Feb 20, 2006 | 09:12 PM
Touch's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (young noob)
so I finally did install the breather and my skunk 2 intake manifold this weekend... not at all what I expected. the breather can and mount is not at all a direct bolt on. Currently, I have the can rigged and the bracket is screwed into one hole. I decided to go for the area on the side of the shock tower, but it gets in the way of the wiring harness and the intake a little. I need to relocate it, but don't want to put it too low. unfortunately, It looks like I will have to drill into my engine bay as well. not looking forward to that either.
Old Feb 21, 2006 | 06:13 AM
Nick M's Avatar
Old Feb 22, 2006 | 09:12 AM
revolt_allmotor's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (Nick M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
nice paint!
Old Feb 22, 2006 | 10:12 AM
Nick M's Avatar
Default Re: Where Did You Mount Your Breather Kits??(Pics Please) (revolt_allmotor)
rattle cans, white gloss lacquer
and all the vac lines are painted black
Old Mar 12, 2006 | 10:28 AM
Touch's Avatar
Still need help... how did you guys mount the canister in the engine bay? I have it rigged right now holding on w/ one screw. How did you guys actually get it to hold in the engine bay? I though a rivet might work, but I won't be able to get it off. Please help... really want to relocate this thing and need some advise. Thanks
Old Mar 12, 2006 | 10:53 AM
Nick M's Avatar
mine has a bracket on it, with a 10mm bolt threaded into a factory hole in the engine bay
