Another charcoal canister, “how do I” thread
Old Nov 5, 2005 | 11:45 AM
abnaasefmb's Avatar
Default Another charcoal canister, “how do I” thread
I’m in the process of turboing my ef. I’ve been looking at that canister with great contempt. I want to get rid of it, but what do I do with all the lines?
How do I hook up the purge cut-off valve? I’m sure I need it right?
What is the red vacuum line running to?
I’m using a map sensor on the throttle body so I don’t need the stock one.
Do I just plug the vacuum port on the throttle body?
Thanks in advance.
Old Nov 5, 2005 | 12:00 PM
Chase's Avatar
Default Re: Another charcoal canister, “how do I” thread (abnaasefmb)
What motor is it?
Old Nov 5, 2005 | 12:02 PM
Chase's Avatar
Default Re: Another charcoal canister, “how do I” thread (EF8kid)
https://honda-tech.com/zerothread?id=1186256
Old Nov 5, 2005 | 12:04 PM
Pee Wee's Avatar
you dont need any of that. just plug em all off and get rid of the can.
Old Nov 5, 2005 | 12:11 PM
Chase's Avatar
Default Re: Another charcoal canister, “how do I” thread (EF8opey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">you dont need any of that. just plug em all off and get rid of the can.</TD></TR></TABLE>
Basically, but the what the hell is that...thing...run a longer hose from it down to where the hose on the bottom of the charcoal canister used to lead to. Its your fuel tank vapor vent
Old Nov 5, 2005 | 12:18 PM
crexer's Avatar
yeah plug everything and throw the canister away, but keep the red hose vent open its the fuel tank vent.
Old Nov 5, 2005 | 12:26 PM
RCautoworks's Avatar
Default Re: Another charcoal canister, “how do I” thread (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">yeah plug everything and throw the canister away, but keep the red hose vent open its the fuel tank vent.</TD></TR></TABLE>
Just make sure you rerout it, because it will smell like fuel in your car if you don't
Old Nov 5, 2005 | 12:38 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">What motor is it?</TD></TR></TABLE>
sorry b16 obd1
Old Nov 5, 2005 | 12:39 PM
abnaasefmb's Avatar
Default Re: Another charcoal canister, “how do I” thread (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Just make sure you rerout it, because it will smell like fuel in your car if you don't </TD></TR></TABLE>
ok, this might be dumb but is there a change of the fumes igniting?
Old Nov 5, 2005 | 12:50 PM
Pee Wee's Avatar
ive been running it like this for over 2 years with no problem so........................
Pee Wee's Avatar
and i didnt reroute mine and i dont smell anything.
Old Nov 5, 2005 | 12:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">
ok, this might be dumb but is there a change of the fumes igniting?</TD></TR></TABLE>
No, I mean there is but thats like me asking you, if there a chance you might hit a brick wall today ?
Old Nov 5, 2005 | 12:53 PM
abnaasefmb's Avatar
No, I mean there is but thats like me asking you, if there a chance you might hit a brick wall today ?</TD></TR></TABLE>
thats funny, and i might.
Old Nov 5, 2005 | 01:01 PM
d357r0y's Avatar
...or you could leave all that **** connected and just do what I did.
Old Nov 5, 2005 | 01:20 PM
Pee Wee's Avatar
Default Re: Another charcoal canister, “how do I” thread (d357r0y)
aahhhhh but its so much cleaner looking without
and yes emo is the new gay
Old Nov 5, 2005 | 01:21 PM
abnaasefmb's Avatar
do i need the purge valve? just keep it pluged in? what does it do? thanks for all the help, i love the ef room not too many ********!
Old Nov 5, 2005 | 01:23 PM
Just unplug it all.
Old Nov 5, 2005 | 01:25 PM
Pee Wee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just unplug it all.</TD></TR></TABLE>
and plug everything off and throw that crap away
Old Nov 5, 2005 | 03:39 PM
abnaasefmb's Avatar
cool but does antone know what the purge cut-off sel. does?
Old Nov 5, 2005 | 04:28 PM
Pee Wee's Avatar
must not be much cuz ive got mine plugged off
Old Nov 5, 2005 | 05:29 PM
Chase's Avatar
dont forget u hafta run a vaccum line from the FPR to the lil port on the back of the Intake manifold. and just unbolt the lil hardlines that are on the IM stock. (if u have a b16)
Old Nov 5, 2005 | 05:47 PM
Surewin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">cool but does antone know what the purge cut-off sel. does?</TD></TR></TABLE>
The purge solenoid is simply an on/off switch for vacuum. The purge solenoid controls engine vacuum, which operates a "valve" on top of the charcoal canister. When grounded, the purge solenoid is closed/off, and doesn't let any vacuum pass through it, so the "valve" on the top of the charcoal canister stays closed. This "valve" is opened when the purge control solenoid allows engine vacuum to pass through. When this valve on top of the charcoal canister is open the engine is "sucking" all the stored gas fumes out of the charcoal canister. Hence the engine is purging the canister of all the gas fumes.
Also, the gas tank does not always vent fumes to the charcoal canister. There is another valve located by the gas tank called the two-way valve. This valve allows a certain amount of pressure or vacuum to build before it opens.
Reasons for/against a charcoal canister:
If a gas tank was perfectly sealed many problems would occur. Such problems include:
1.) The fact that pressure changes with temp (PV=nRT), so when it get hotter outside, the pressure or volume will have to get more/bigger
2.) As gas is pumped out of the tank a vacuum would occur in the tank.
So now we have established that a gas tank HAS to be vented.
Remember the 1970 clean air act? Cars before 1970 and trucks before 1976(?) didn't have any way to catch these gas fumes. The tank was simply vented to the atmosphere. This vent was generally located near the gas cap, or was the gas cap.
On my CRX, I completely removed the metal pipe that is sticking out of the firewall. This is the small pipe that connects to the red hose. I didn't want to just leave it, because I though it would look stupid. Now if you look underneath the car, by the gas tank you will see a small plastic cover on the drivers side. Remove this cover, and disconnect the hose here after the two-way valve. Now gas fumes will vent back here and not in your under hood. I’ve been driving my CRX like this for more then 1 year and haven’t had any problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">and plug everything off and throw that crap away</TD></TR></TABLE>
If you simply plugged the port that the red hose is connected to, how is air going to enter the tank as the engine draws fuel out of the tank?
Old Nov 5, 2005 | 07:36 PM
Pee Wee's Avatar
Default Re: Another charcoal canister, “how do I” thread (Surewin)
you got me. that i did leave open
surewin:1
opey:0
Old Nov 5, 2005 | 08:05 PM
Surewin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">you got me. that i did leave open</TD></TR></TABLE>
Has your gas cap been pressure tested lately? Maybe it leaks.
Old Nov 5, 2005 | 11:32 PM
Contender25
Guest
Posts: n/a
So im guessing you can only do all this **** when you have a map on you're throttle body. Other wise it's not a good idea i would think, idk how you can just plug all those lines and still not have a problem though with idle and ****.
