Car won't start
Old Nov 5, 2005 | 10:56 AM
fanatic's Avatar
Default Car won't start
Tried to start car this morning and it does nothing. Started it yesterday plenty of times while running around, but this morning, nothing. There's no click or anything when you turn the key. It's not the battery, all of the electronics turn on fine and show no signs of dimming.
A few things I noticed was that when I turn the key, it resets the stereo head unit. I put the key in the ignition and turn it to on and the stereo will turn on to start playing, but when you turn the key to start the stereo turns off and restarts when you release the key. There is a faint click you can hear from the engine bay that sounds like it's from around the battery, so I don't know.
Any ideas would be appreciated.
Old Nov 5, 2005 | 01:19 PM
GoCarInteg's Avatar
Default Re: Car won't start (fanatic)
you might want to check your connections to the battery..making sure that they're on completely. if not, then possibly starter problem.
Old Nov 5, 2005 | 01:34 PM
JDM-EJ1's Avatar
Default Re: Car won't start (GoCarInteg)
Does the fuel pump prime? Are you getting spark?
My Accord did the same thing, worked great one day.. Wouldn't start the next, turned out to the distributor.
Old Nov 5, 2005 | 01:40 PM
SlamminS85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah but it should do that anyway, using the starter should use most of your electric current, thats why your lights will flash your headunit turns on and interior lights dim, the turning off of your headunit happens to protect your headunit from damage... what you do want to look for in your headunit if you suspect electrical problems is if the headunit looses all of the saved features like balance, fading, anything stored in the headunits RAM... radio presets is a good thing to look for, if those are gone then it could be a problem with the batt, if the presets are gone, then your battery has problems or you blew a fuse
Old Nov 5, 2005 | 02:01 PM
eg2.0dart's Avatar
check main relay
Old Nov 5, 2005 | 06:00 PM
JERKthisDC2's Avatar
i think you have to check the connections to your batt. because that happened to me too buddy
G2integra217
Jan 30, 2007 09:14 AM
slow_redcivic
10
Apr 9, 2006 04:57 PM
jDm-Ek9
Jul 22, 2005 01:23 AM
alfee
Apr 4, 2005 07:03 PM
lowblazin
Nov 25, 2003 10:00 AM
