Best way to lay cyl. head so it doesnt warp?
Hey I am pulling my cy. head right now and im gonna have to leave it off the block overnight, how should i sit/lay it so that it doesnt warp?
thanks
thanks
you shouldn't have to many problems if its a climate controlled area and temp doesn't fluctuate too much. Putting it on a piece of wood is a good idea, although exhaust side down really isn't neccesary.
on a large piece of glass. block side down. glass is flat. also the best way to tell if a head is warped. better than a straight edge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">on a large piece of glass. block side down. glass is flat. also the best way to tell if a head is warped. better than a straight edge.</TD></TR></TABLE>
uh how is that better than a straight edge? glass can bend you know.
that sumbitch wont warp just by sittin on a regular table or floor unless for some reason the temperature gets above 500 degrees F.
just dont put the valves flat on a table use 2 peices of wood on each end of the head and put it on a table with the valves down do they are not on the table
it will be fine
it will be fine
Dioxine
Jan 15, 2012 07:09 PM
