ac/ heat will not blow.
Old Nov 5, 2005 | 08:18 AM
DreamCatcher's Avatar
Default ac/ heat will not blow.
My ac/ heat will not blow. When turning the climate controls, I can hear the fan click, but it will not blow. What could this be?
Old Nov 11, 2005 | 06:43 AM
Default Re: ac/ heat will not blow. (DreamCatcher)
anybody
Old Nov 11, 2005 | 06:45 AM
zccr-xsi's Avatar
u see if the blower motor was pluged in?
Old Nov 11, 2005 | 10:52 AM
CRXb18Turbo's Avatar
Default Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">u see if the blower motor was pluged in?</TD></TR></TABLE>
Or blown fuse/motor...
Old Nov 12, 2005 | 08:02 AM
Where does it plug in?
Old Nov 12, 2005 | 08:37 AM
SiMateoAko's Avatar
Check to see if it worked at the highest fan setting. If it does then the fix is an easy one.
Old Nov 12, 2005 | 09:05 AM
migizzel's Avatar
Default Re: (SiMateoAko)
what if it didnt blow on the highest setting what to do next
my hatch just stop blowing but it will work til the 3rd setting so how can i fix this
Old Nov 12, 2005 | 09:53 AM
tommycrx's Avatar
Default Re: (migizzel)
Check the resistor box - do a search; it's a small, annoying box behind the glove box, with one wire for each speed. If you get some speeds working, and not others, it's probably the resistor - buy a new one from dealer for about $30 (but check to make sure that that's what the problem is first, of course).
Old Nov 12, 2005 | 10:30 AM
migizzel's Avatar
Default Re: (tommycrx)
i also heard that there is a relay somewhere is this true and how can i check all this also do i have to take my dashboard off to get to it?
Old Nov 12, 2005 | 11:00 AM
sohcef9's Avatar
take off ur glove box and most of the plugs for the ac/heat are in near the black casing and on the side near the door.
Old Nov 12, 2005 | 11:16 AM
migizzel's Avatar
Default Re: (sohcef9)
thanks dude
Old Nov 15, 2005 | 03:56 PM
yeah thanks for helping.....
Mine wont blow on any setting. I can hear the motor react to the pressing of the ac, but I don't get any air..
Old Nov 15, 2005 | 09:18 PM
tapuout's Avatar
I have same issue on 90si. Just got a blower motor off ebay. Hope this is an easy replacement/install? any help would be great on this install. Thanks!
1320whtrex
17
Dec 2, 2025 03:47 PM
kaylawoolley
Oct 11, 2017 03:28 AM
nonno
Honda Civic (2001 - 2005)
Jun 17, 2014 06:06 PM
nlmoua
Sep 11, 2009 04:29 AM
grey_ghost
Sep 21, 2007 09:53 PM
