Adding a tachometer to DX
Old Nov 5, 2005 | 07:06 AM
2000_CivicDX's Avatar
Default Question on adding a tachometer to DX
DX model doesn't come with a tach and I am planning to add one to it. Is it a job that any mechanic can do it? When shopping for tach, does the brand really matter in terms of accuracy?
Old Nov 5, 2005 | 07:07 AM
poison's Avatar
Default Re: Adding a tachometer to DX (2000_CivicDX)
I'd recommend just purchasing an EX or Si gauge cluster. But if you must, I'd say you would want an autometer.
Old Nov 5, 2005 | 07:10 AM
Default Re: Adding a tachometer to DX (poison)
but if I do that, the odometer will be different and I think I will need to file additional paperwork to DMV for it? I saw those from autometer but I went for the one from Summit at prostreetonline. Would that be bad in terms of accuracy? (I don't really care how it looks). Is it easier to install a new cluster?
Old Nov 5, 2005 | 07:15 AM
97civicdx's Avatar
so swap old speedo to new cluster. It isnt that difficult
poison's Avatar
a new cluster is a lot easier. it's just swap plug and play. you can have the mileage match. just a pain in the ***.
Old Nov 5, 2005 | 07:40 AM
I think for the EX, redline starts at 7000 rpm, is that true for DX as well? If not, would the rpm reading be off?
Old Nov 5, 2005 | 07:43 AM
poison's Avatar
The redline for the D16Y8 (EX) is 7200, and the redline for the D16Y7 (DX) is 7100. So not that much difference.
And no, it would be the same for accuracy.
Old Nov 5, 2005 | 07:48 AM
T-RO's Avatar
if youre looking for a monster tach though ive got one for sale.
Old Nov 5, 2005 | 08:00 AM
Royal_C!ty's Avatar
Default Re: Question on adding a tachometer to DX (2000_CivicDX)
Yeah like everyone says pick up the Ex/Si cluster ...
looks better & doesn't attract as much attention, unless you like the big *** shift light from the moster tach blinding you
Old Nov 5, 2005 | 08:59 AM
93CX's Avatar
Default Re: Question on adding a tachometer to DX (eg8kid)
I have a 5" autometer and I like it, some people say its rice but when you're revving high its definatly functional for accuracy. I have an lx cluster w/ tach too and I like to compare the readings I get from both tachometers and see how much the stock one is off. Its more than you'd think.
On the other hand, if its just a daily driver theres no need for an autometer. Just get an Ex cluster.
Old Nov 5, 2005 | 09:04 AM
cchhrriiiss's Avatar
So just plug and play? No wires have to be added or anything?
Old Nov 5, 2005 | 09:21 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">I'd recommend just purchasing an EX or Si gauge cluster.</TD></TR></TABLE>
Don't get a big tach, just get an OEM cluster.
Old Nov 5, 2005 | 09:33 AM
kkim's Avatar
Default Re: (ChrisBrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisBrown &raquo;</TD></TR><TR><TD CLASS="quote">So just plug and play? No wires have to be added or anything?</TD></TR></TABLE>
Yes, plug and play. I have an EX cluster in my CX. Clean, neat, simple install. I did swap the speedometer from my old cluster to the new to keep the mileage accurate. Very simple to swap the speedometer over. Hardest part is finding a cluster to buy in good shape. I recommend the EX cluster due to th similar redlines between the EX and DX.
Old Nov 5, 2005 | 09:39 AM
JDM-EJ1's Avatar
Yup, that ***** will go right in there!
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">Yes, plug and play. I have an EX cluster in my CX. Clean, neat, simple install. I did swap the speedometer from my old cluster to the new to keep the mileage accurate. Very simple to swap the speedometer over. Hardest part is finding a cluster to buy in good shape. I recommend the EX cluster due to th similar redlines between the EX and DX.</TD></TR></TABLE>but the Ex and SI are the same...
Old Nov 5, 2005 | 09:43 AM
JDM-EJ1's Avatar
Default Re: (honda 3300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda 3300 &raquo;</TD></TR><TR><TD CLASS="quote">but the Ex and SI are the same...</TD></TR></TABLE>
Exactly. They come in a EG Si hatchback, or an EX coupe, or ferio.
Old Nov 5, 2005 | 09:56 AM
kkim's Avatar
Not on the EK. Redlines for EX and SI are different. I'm assuming he has an EK based on the original poster's user name.
Old Nov 5, 2005 | 10:10 AM
FullJDMEg's Avatar
but if he already knows his redline now, why try to push it further on the EK's ex or si cluster. right
Old Nov 5, 2005 | 10:36 AM
stupdjack's Avatar
Default Re: Question on adding a tachometer to 94 civic DX
i have a 94 civic dx and want to put in the 5 inch autometer tach.Do u have a wiring diagram or have any idea where i can get 1?
Old Nov 5, 2005 | 10:44 AM
Default Re: Question on adding a tachometer to 94 civic DX (stupdjack)
ok I just got myself a 99 Civic EX gauge cluster and I assume that the EK EX and DX have similar redline and drops right in (I was getting confused with the later posts). Please confirm.
Regarding where to get the tach, I remembered I saw a 5 inch one by Autometer and it is around 80 dolllars. However, I don't know if the wiring comes with it. I originally just wanted to add a tach as it is cheaper but it probably will cost more labor to install and so I decided to just go get the EX cluster.
Would any regular mechanic shop be able to install that no problem? The seller would adjust the milage for me so I guess I don't even need to swap the speedo.
Old Nov 5, 2005 | 10:50 AM
kkim's Avatar
Default Re: Question on adding a tachometer to 94 civic DX (2000_CivicDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000_CivicDX &raquo;</TD></TR><TR><TD CLASS="quote">ok I just got myself a 99 Civic EX gauge cluster and I assume that the EK EX and DX have similar redline and drops right in (I was getting confused with the later posts). Please confirm.
Yes to all of the questions above. You might want to consider installing yourself. If you've got a stubby phillips to access the cluster bezel screws, the rest is a piece of cake.
Search around HT for past posts about swapping the clusters out.
Old Nov 5, 2005 | 11:46 AM
black_EM1's Avatar
Community Builder
Community Influencer
If Iremember correctly, it's the green wire on the the driver's side right in front of the windshield. I'd be more helpful, but my memory isn't the best
Old Nov 5, 2005 | 12:23 PM
97civicdx's Avatar
Default Re: (black_dohc)
The black plastic bezel has two snaps near the guage cluster face. Try not to break those snaps. Its not a big deal if it does brake. The cluster has two or three big molex plugs in the back, it fits only in its own plug on the new cluster.
If you want to swap speedos, the acrylic face unsnaps at like 8 points in the back of cluster housing. Then remove the face, unscrew the guage , and swap in your old speedo. Be careful of the green plastic electric connection sheet as u remove/install the speedos.
Its really easy if you like tinkering.
Good luck.
I have an EX cluster in my 97 DX right now. I also have an SI cluster to put in once I do my swap, hehehe............................
Old Nov 5, 2005 | 01:22 PM
Default Re: (97civicdx)
Thanks. I found a website that taught you how to change the bulbs of the cluster and basically it says that there are two screws in front of the cluster face for the bazel and three screws for the cluster. So after I unscrew everything and pull it out, are the wiring hard? I saw that there are two sets of wires and I guess I just plug each set back to the new one at the same position? Please let me know.
Old Nov 5, 2005 | 01:25 PM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">a new cluster is a lot easier. it's just swap plug and play. you can have the mileage match. just a pain in the ***. </TD></TR></TABLE>
How do you get that done..?? I got the JDM Gauge Cluster w/ 8200 r/l in my 94 dx coupe, an its on like 154K km, an my motor is at like 40K.... I kno that u can like take the whole thing apart an manually like spin it with ur hands all the way back an back an back an back, is that what u were talking about as being the pain in the ***..??
