b16a?
Old Nov 5, 2005 | 06:28 AM
jonbouy's Avatar
Default b16a?
hi i was just wondering whats the difference between a b16a1 and the b16a2 ? as i am buying one of these
Old Nov 5, 2005 | 06:31 AM
G2 Speed's Avatar
Default Re: b16a? (jonbouy)
https://honda-tech.com/zerothread?id=878010
I think you would find most of your answers in there.. also google it
Old Nov 5, 2005 | 06:35 AM
jonbouy's Avatar
Default Re: b16a? (G2 Speed)
thanks for that but i have oready read this one!... it doesnt tell the what the actual difference is ?
Old Nov 5, 2005 | 06:37 AM
G2 Speed's Avatar
how about this
B16A1
* Found in:
o 1989-1992 EDM Honda CRX 1.6i/VTi (EE8/ED)
+ Displacement: 1595 cc
+ Compression: 10.2:1
+ Power: 158 hp (117 kW) @ 7600 rpm & 111 ft·lbf (152 Nm) @ 7000 rpm
o 1990-1991 Honda Civic SiR (EF)
o 1990-1991 Honda CRX SiR (EF)
+ Compression: 10.4:1
+ Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (152 Nm) @ 7000 rpm
B16A2
* VTEC
* Found in:
o 1992-1995 JDM [[Honda Civic](EG)
+ Power: 160 hp (118 kW) @ 7600 rpm & 116 ft·lbf (152 Nm) @ 7000 rpm
o 1996-2000 Honda Civic VTi (EK)
+ Power: 168 hp @ 7800 rpm & 126 ft·lbf (171 Nm) @ 7300 rpm
o 1999-2000 Honda Civic Si (EM)
+ Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 Nm) @ 7000 rpm
+ Transmission: Y21
credits : http://en.wikipedia.org/wiki/Honda_B_engine#B16
Old Nov 5, 2005 | 06:40 AM
jonbouy's Avatar
oh thanks for that 1 m8
Old Nov 5, 2005 | 06:41 AM
jonbouy's Avatar
which one woud you say is better ?
Old Nov 5, 2005 | 06:43 AM
G2 Speed's Avatar
yea no problem.. I would say b16a2 anyday... but..... go for b18 and up
Old Nov 5, 2005 | 06:44 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonbouy &raquo;</TD></TR><TR><TD CLASS="quote">which one woud you say is better ?</TD></TR></TABLE>
Look at the numbers and figure it out.
Old Nov 5, 2005 | 06:45 AM
jonbouy's Avatar
i have got a chance of getting a b16a2 1992-1996 out of a eg why do you think that it is better ? more performance upgrades ?
Old Nov 5, 2005 | 06:47 AM
G2 Speed's Avatar
1. It's a newer motor
2. it's 92-95
Old Nov 5, 2005 | 06:59 AM
Capt. Jimbo McSubipants's Avatar
you could buy my 00 B16a2....
Import_Dumbass's Avatar
whats a civic VTi
Old Nov 5, 2005 | 07:00 AM
G2 Speed's Avatar
Default Re: b16a? (Import_Dumbass)
If i'm not wrong it's the uk model..
Vti is like our Si
Old Nov 5, 2005 | 07:01 AM
poison's Avatar
B16A1, there is no such thing. Many people say that referring to the 1st gen B16A which is found in the CR-X SiR with a PW0 ECU (OBD0).
B16A2 is found in the US 99-00 Civic Si with a P2T ECU (OBD2b).
The 1st gen B16 has softer cams, is older, and usually comes with a cable tranny.
The B16A2 is OBD2 and is more suitable to swap into 92-00 Civics.
Old Nov 5, 2005 | 07:03 AM
G2 Speed's Avatar
Default Re: b16a? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">B16A1, there is no such thing. Many people say that referring to the 1st gen B16A which is found in the CR-X SiR with a PW0 ECU (OBD0).
The B16A2 is OBD2 and is more suitable to swap into 92-00 Civics. </TD></TR></TABLE>
b16a2 is not just found in the 99-00 Si
Old Nov 5, 2005 | 07:05 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
b16a2 is not just found in the 99-00 Si</TD></TR></TABLE>
You're right. The only other one it's found in is the US 1996-1997 del Sol VTEC.
Old Nov 5, 2005 | 07:17 AM
G2 Speed's Avatar
92-95 eg in japan SiR
99-00 Sir Canada
Old Nov 5, 2005 | 07:19 AM
poison's Avatar
92-95 EG in japan is B16A.
and canada? psh. doesn't matter when it comes to them.
Old Nov 5, 2005 | 08:41 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">You're right. The only other one it's found in is the US 1996-1997 del Sol VTEC.</TD></TR></TABLE>
I thought those were a3's
Old Nov 5, 2005 | 09:07 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: b16a? (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
I thought those were a3's</TD></TR></TABLE> i think ur right, a2's are the obd2 version
Old Nov 5, 2005 | 09:52 AM
poison's Avatar
B16A3's are found in 94-95 del Sol VTEC's.
JDM*addiction
Nov 22, 2023 04:10 PM
ghostTEGI13
Jul 14, 2015 12:09 PM
Kilpuri
Jul 28, 2009 10:35 PM
sslude
Feb 28, 2003 09:13 PM
