GARAGE SALE! Turbo Stuff...A/C, P/S....Chips, P28s
Just as title states, I have a Dual RFL BOV, the horns are removable....mounted on a charge pipe...fits civics and integras
Painted aluminum.....quality welds....made by spoolinperformance
120 OBO
Also still trying to get rid of this stuff all prices are OBO:
-Tial 35mm wastegate flange
$10 bucks
-P28 auto that was converted to 5-speed
$110
-I have about 3 extra ZIF sockets and a chips.
$20 bucks for a ZIF socket and chip, can burn any bin you want, or I can make you a custom basemap for your OBD-1 turbo setup. I use Crome which makes better basemaps than uberdata because it has Step retard. For example i can set it to pull .15 degrees of timing per lb of boost from 1-3 psi, .25 from 3-5 psi, .5 degrees per 5-8, and .75 degrees per 8+ psi or whatever. Also can do 2 step launch control, change VTEC crossover, change revlimits.....even make the CEL flash as a shift light.
-b16a3 clutch with only 54k miles that I'd liek to get rid of. It's OEM, in great shape. I have the pressure plate, flywheel, and clutch disc.
$Give me money damnit. make an offer
-10 feet of never used 0/1 gauge knukonceptz.com power wire.
$10 bucks
-Also have a COMPLETE A/C system out of my 93 coupe....and A P/S pump. take this junk away.
-Precision Power PCX-250, good shape, under rated: 50 x 2@4ohm, 100 x 2@2ohm, 250x1@4ohm bridged.
-$90
Remember! Prices are best offer!
120 OBO
$10 bucks
$110
$10 bucks
-$90
