engine bearings
Old Nov 4, 2005 | 09:44 PM
supra8588's Avatar
Default engine bearings
which engine bearing would you use
i have a gsr and will be boosted what bearings will take the punishment
and for a while
Old Nov 4, 2005 | 11:15 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: engine bearings (supra8588)
stock gsr bearings with the proper clearances
Old Nov 11, 2005 | 04:52 PM
boost'd_crx's Avatar
you can go with stock or with acl
Old Nov 11, 2005 | 06:40 PM
PrettyLude's Avatar
you can use any bearing you want, just make sure the machinst or the assembler is comfortable with them, it doesn't matter the bearings, just the clearances and installation
Old Nov 11, 2005 | 11:21 PM
D@nnY's Avatar
acls are generally honda green which are right in the middle...
you ahve to check the sizes ont he block and crank and see what your motor asks for.... if it wants blacks blues or yellows the acls will not be for you
Old Nov 12, 2005 | 02:56 PM
h22 civic's Avatar
Default Re: (D@nnY)
anyone ever use clevite77 race bearings?
Old Nov 12, 2005 | 04:01 PM
built4cubanlynxx's Avatar
Default Re: (h22 civic)
Ihave heard from good honda builders that stock honda are almst the best and are used in nascar motors .Also King bearings are good and are cheaper than stock honda.
triple check clearences to be sure good luck
Old Nov 12, 2005 | 07:51 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever use clevite77 race bearings?</TD></TR></TABLE>
I use em in my chevy. Went with honda when i put the little bastard together though.
vestalfootball72
10
Oct 1, 2006 12:04 PM
9seccivicsi
Jan 19, 2004 05:30 PM
JDMCRX
Oct 27, 2003 08:35 AM
Soon_2b_evil
Jun 16, 2003 01:25 PM
jdmR
Aug 12, 2002 11:00 AM
