Clutch issue
Old Nov 4, 2005 | 06:21 PM
EG2Driver's Avatar
Default Clutch issue
Sorry for the boring title....anyways when i slip it in first, it makes the car jerk sometimes. Only in first tho. Got a hydro tranny. My bro's all the gears ir u slip it it'll make the car jerk. What gives? oh and when i mean jerk, i just mean the car shakes a lot. Thanks
Old Nov 4, 2005 | 07:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Clutch issue (deadend9009)
check the clutch pedal adjustment. you may have a master cylinder goin south.
Old Nov 4, 2005 | 08:02 PM
EG2Driver's Avatar
Default Re: Clutch issue (boostedcivicsir)
how do you do that? How hard is it to change that?
Old Nov 5, 2005 | 04:04 AM
Mr. Badwrench
rest your hand on the pedal, it should move freely about 3/4" to 1" before it starts to build fluid pressure. if it is more than that it will not fully disengage the clutch and you will grind it putting it into gear if it goes in at all. to adjust it, there is a 12mm nut on the clutch linkage at the top of the pedal. loosen it and turn the rod till you have adequate pedal travel. but before you do all that, check it for leaks up by the firewall where the pedal is. look in your reservoir also to see if it is low.
Old Nov 5, 2005 | 04:32 AM
EG2Driver's Avatar
ur da man. Thanks a lot
Old Nov 5, 2005 | 04:48 AM
Mr. Badwrench
n.p. i just hope you understand that all. he hee. it is easy if you work on cars but if you dont sometimes it is hard to understand whats goin on.
david236kEG
23
Jan 28, 2009 03:34 PM
Lb1atx
Sep 7, 2007 05:16 AM
The Droogan Leader
Oct 6, 2006 12:05 PM
SPOOLINmatt
Mar 14, 2005 01:04 PM
notstock93
Jan 14, 2005 03:24 PM
