are my vaccum readings correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">I was always seeing about 26" at idle and went to 0 at WOT</TD></TR></TABLE>
that is correct. sounds like your gauge is f'd up.
At WOT the TB is completely open, no restriction, so it has to be 0. Unless you're cable is set wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">that is correct. sounds like your gauge is f'd up.
At WOT the TB is completely open, no restriction, so it has to be 0. Unless you're cable is set wrong.</TD></TR></TABLE>
If he's seeing negative pressure at WOT he could have a dirty *** air filter in there. But that's a serious *** restriction though to be reading 15".
you need to check your gauge with a controlled vaccum source. i do not think your gauge is correct. i haven't seen a honda ever idle above 25 inches of vaccum. most mechanics will agree that a standard gasoline engine should have around 18 to 22 inches of vaccum. you can also measure the vaccum measured by your map sensor by using your multimeter.
gtowni3
16
Oct 9, 2004 10:53 AM
