Oil Pan removal
Old Nov 4, 2005 | 05:50 PM
Cuong-nutz's Avatar
Default Oil Pan removal
Do I need to remove the flywheel access plate in order to remove the oil pan? Reason being is because one of my bolts to the access plate is really stripped badly and I can't remove it.
Also, I should be okay pounding the dents out of my oil pan right?
Old Nov 4, 2005 | 07:52 PM
nocturnaldragon's Avatar
Default Re: Oil Pan removal (Cuong-nutz)
What kind of motor is it?
If its a D-series you have to remove the bolts holding it in. They also hold the oil pan in place, there not bolts so much as studs. The third one goes to the block and has to be removed along with the plate because it sits on the pan and will be in the way.
Old Nov 4, 2005 | 08:20 PM
Cuong-nutz's Avatar
Default Re: Oil Pan removal (nocturnaldragon)
It's an auto D15b7.
Aww Hell. Looks like I'm going to have to buy me a Dremel tool to grind that bolt out. I can't drop the tranny because of that too.
Old Nov 4, 2005 | 10:27 PM
Yea, you want to remove the stud completly tho because its going to have to be replaced, if not you MAY have a leak from that area.
lazyxmofo
Mar 9, 2011 06:26 PM
civicSF98
Jul 20, 2009 09:24 AM
khilgers
Honda Civic (2001 - 2005)
Jun 2, 2009 07:56 PM
silverskateEF9
Mar 6, 2008 06:48 PM
02 coupe
Jun 25, 2003 01:56 PM
