REALLY low compression test result
Just did a compression test on my 92 B18A w/169,000 miles. Somewhat warm engine, cranked 5-6 times each, and held the throttle open. Got between 118-120 on all. Im pretty sure the gauge is accurate, but the engine doesnt burn oil and feels very strong. Only problem is that i do have loud piston slap in the motor when its cold.
Is it possible that its actually that low and not burning any oil???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonspeed »</TD></TR><TR><TD CLASS="quote">friend of mine did his 92 ls and got 155 across the board. was your engine warmed up?</TD></TR></TABLE>
Good point.
As long as the numbers are consistent, you should be fine.
Good point.
JKing106
Sep 10, 2012 02:30 AM
92integraVTECgsr
Apr 1, 2006 11:11 AM
