New H22 swap....some cel's.....
Old Nov 4, 2005 | 05:30 PM
dhn's Avatar
dhn
Default New H22 swap....some cel's.....
well...got my car from the shop after getting tops and iat sensors on and adjusted...i drive and a cel flasshes,....i jump it n check it...its code 12....egr valve..i have a 91 accord btw with the swap..anywho...i put vacuum 16 on the egr valve...and later ill reset ecu..but when i went to get gas..i filled it up....then car wouldnt start..after like 5 min of waiting and crasnking it started....then cel popped on..i thought it was the code 12 again...but i jumped it anyway..and got a knock sensor code out of nowhere..code 23..also....my idle is so gay...it fluctuates when i put it in park..after i drive...say id rove to school..then park it...it fluctuates between 1000-15000 back and forth then finally stays steady..drops abit....idk its weird..and while driving when i elt off the gas..the rpm goes down to like 1000..its weird..any help is appreciated thanks guys
Old Nov 4, 2005 | 05:34 PM
AP1's Avatar
AP1
Take more time making sense so we would first consider helping you. No offense, but I didn't get half of what you said. Grammar > You
dhn's Avatar
dhn
plus my water temp guage isnt working..it goes to maybe the middle..and comes down very slowly..somtimes doesnt even go all the way up or w/e
im also smelling oil when i open my hood..as well as when i walk around the hood area...normal?
Old Nov 4, 2005 | 05:36 PM
dhn's Avatar
dhn
cel codes:12,23
both are egr valve....and knock sensor
filled up car with gas....car wouldnt start.....car started after while.checked the cel's....and then the code 23 came up..which i didnt have before....had the 12 first..then after filling up..got the code 23
i have fluctuating idle.....after driving and putting into park..idlke fluctuates from 1000-1500 rpms...then stays at around1..maybe a bit lower...rpm's also drop while crusing
Old Nov 4, 2005 | 07:39 PM
dhn's Avatar
dhn
up for some help...
Old Nov 5, 2005 | 02:45 PM
MadCityLude
Guest
Posts: n/a
Default Re: New H22 swap....some cel's..... (dhn)
Your water temp guage shouldnt go all the way up! If your talking a stock temp guage it shoul run in the middle somewhere. Dont know where you are from but here it is getting cold and when I start to drive my temp falls do to cold air.
EGR valve I know nothing about, but hte knock sensor means you have a KNOCK in your engine.
Smelling oil could be a leak somewhere. Check the valve cover, Oil cooler (under the oil filter) and the oil pan.
d601
Jul 29, 2011 05:04 PM
Projectludatic
May 25, 2010 02:59 PM
angelgsrteg
Dec 28, 2004 05:29 AM
