Ran Out of Gas Now Won't Start!!!!!!!
Old Nov 4, 2005 | 04:54 PM
smash fascism's Avatar
Default Ran Out of Gas Now Won't Start!!!!!!!
I was driving home and thought that I could make it, but apparantely I couldn't. I was driving then all of a sudden a lot of black smoke came out of my exhaust and the car stuttered and stalled, but I coasted to a stop. I got a ride to a gas station and bought a gallon of gas and put it in the tank. After pouring in the gas I tried cranking the car over and nothing. Just a click. I have all of my lights and my radio. I've checked every fuse in the car. I can hear my fuel pump priming. Could running out of gas and trying to crank the car over, caused my starter to go bad? I'm at a loss and need help bad. Thanks in advance.
Cliffs:
Ran out of gas
won't start now/just clicks
good battery
starter bad?
Old Nov 4, 2005 | 04:59 PM
my_slow_civic's Avatar
Default Re: Ran Out of Gas Now Won't Start!!!!!!! (smash fascism)
If the starter just clicks now, sounds more like a coincidence than anythig.
Old Nov 4, 2005 | 05:00 PM
AntF's Avatar
I wish I could give you serious help, but I can give you a suggestion based on my observations. I was running pretty low on gas for a week, and I noticed my car had a really hard time starting up. I would have to crank for 5+ seconds, and it started to scare the crap out of me. But once I put in a full tank, the car started up just fine.
Maybe put in a few more gallons? :/ I know you stated that all you get is a click when you crank, but I don't think it would hurt to try. Sorry.
Old Nov 4, 2005 | 05:05 PM
808_si's Avatar
maybe your fuel pump sucked up some sludge and it's now stuck in your fuel filter? i don't know. maybe swap batteries and see what happens...
Old Nov 4, 2005 | 05:13 PM
si0385.'s Avatar
check the wire from the battery to the starter maybe a fusible link poped, but it sounds like more of coincidence than anything
do u got power at the starter???
Old Nov 4, 2005 | 05:16 PM
I haven't tested the starter yet. The key turns all the way over and it just clicks once. I will try putting more gas in it. Any other suggestions?
Old Nov 4, 2005 | 05:20 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default Re: (smash fascism)
Jump it.
Old Nov 4, 2005 | 05:31 PM
It has no effect at all, should've written that. I already tried jumping it, my battery has juice, when I hook the jumper cables up it still just clicks.
Old Nov 4, 2005 | 06:25 PM
808_si's Avatar
can you kick start it?
Old Nov 4, 2005 | 06:27 PM
Frozen E's Avatar
H-T White Ops
Default Re: (808_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si &raquo;</TD></TR><TR><TD CLASS="quote">can you kick start it?</TD></TR></TABLE>
He has a point
Slow EJ8's Avatar
lol, I read your title and I was like hrm, of course if you dont have any gas your car wont start....
ok now ill try to help. Here is a thread I found and I will quote what I think pertains to your problem (the "So you hear a clink noise..." part). Thanks to the original poster B18C5-EH2
Originally Posted by B18C5-EH2
So you hear the "clink" noise, but still no starting, eh?
Well now it's time to dig a bit deeper. you need to figure out if you're not getting spark or fuel. 99% of spinning over, but not starting problems are from either no fuel or fire. the other 1% is no compression, and that just isn't common.
1. Checking for spark.
Grab up a long screwdriver and pull one plug wire out of the cylinder. Stick the tip of the screw driver into the plug wire end far enough to make contact with the metal tab in the wire to the tip of the screw driver. Tilt the handle of the screwdriver so that you hold the shaft of the screwdriver near any metal surface - i use one of the valvecover hold down nuts. Have a friend (if you have any) spin the car over. If you see sparks between the shaft of the screwdriver and the other metal surface, then you have spark. If not, then you have a problem getting spark then.
2. If you have no spark then there are a few different parts that can cause this. *Usually* it is the ignition coil, loctaed inside your distributor. It is a little box with a spring sticking out of it with a goldish case around it, and it's held in with two phillps screws once you get your car and rotor out of the way. I don't know of any real way of checking one out of the car other than replacing it with a known good one. A lot of times the coil will have burn/flash marks on it if it's bad, or going bad. a new coil from honda is about $90.00.
3. The other common (but not as common as the coil) is the ignitor module. It is a flat plastic-looking piece inisde the distributor with a few tabs with wires hooked up to it. I believe it's also held in with a few screws. again I know of no visual cues that an ignitor is bad, so if you can get another, try it out. a new ignitor from Honda is also about $90.00.
4. Another blanket way to fix the no spark would be a good new distributor from http://www.distributorking.com. this way you get a new base with sensors, coil, ignitor, cap, rotor, etc. all for a little more than the cost of an ignitor or coil.
The last item that can cause spinning over, but not starting is the ignition switch pigtail assembly. When these go bad they typically allow the car to crank for a second, but then it shuts right back off. I diagnose these by simply cranking the car and backing off the key just enough to disengage the starter, but still be in the full "crank" position. If you let go of the key and it springs back into the normal position and the engine dies, you need a new ignition switch pigtail/electrical portion. do not confuse this with the entire ignition assembly with lock cylinder - it's just the electrical harness. These are pretty cheap, but a PITA to install.
Hope this helps some of you guys.
Now what if the main relay works, and you have spark, but still no starting?
Time to check for fuel, and it's easy.
Grab a 12mm wrench and loosen the banjo nut on top of your fuel filter, and have someone turn the key into the "on" position - he may not even have to try and spin the car over. If you get no fuel spray, then you are not getting fuel, and if the main relay is in fact working, it's time for a fuel pump.
The fuel pump is located in an access panel under your rear seat cushion. I personally would try and find a used Integra fuel pump or even a new one if you can afford the pricetag - aftermarket ones suck ***. I say Integra because it's an upgrade, especially if you can get a GS-R one.
Hope some of this helps.
(oh yea, original thread and full version here: https://honda-tech.com/zerothread?id=1320931 )
Old Nov 4, 2005 | 06:32 PM
Thanks a lot slow ej8. I'll try and diagnose it further.
Old Nov 4, 2005 | 06:34 PM
. L i z's Avatar
have you put more gas in it since you have started your diagnosis. I know from experience that sometimes if you run out of gas for some reason you have to put a whole lot in the tank to get yourself going again.
Old Nov 4, 2005 | 07:07 PM
Slow EJ8's Avatar
np, let us know if it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilhondagirl &raquo;</TD></TR><TR><TD CLASS="quote">have you put more gas in it since you have started your diagnosis. I know from experience that sometimes if you run out of gas for some reason you have to put a whole lot in the tank to get yourself going again.</TD></TR></TABLE>
Thats true too, maybe if you only put in a little gas (gallon or whatever) it filled up some reserve or something and is not getting all the way to the engine. Not sure if that makes sence of if its even possible, ah i dunno im tired and my head hurt... too much thinking.... good luck with it all.
Old Nov 6, 2005 | 05:20 AM
I put in 4 more gallons and it just clicks still. I can hear the pump priming, but nothing.........
Old Nov 6, 2005 | 05:47 AM
pinoy369's Avatar
+1 on the starter. Maybe you have to directly link the positive power to starter solenoid(thats what i did). Hope this helps. Try it out let us all know if any progressment.
Old Nov 6, 2005 | 06:30 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smash fascism &raquo;</TD></TR><TR><TD CLASS="quote">I put in 4 more gallons and it just clicks still. I can hear the pump priming, but nothing.........</TD></TR></TABLE>
Push start it. If it starts that rules out everything but your starter.
Old Nov 6, 2005 | 11:02 AM
808_si's Avatar
yep, that's what I suggested a couple days ago...
Old Nov 6, 2005 | 02:41 PM
Negative on the push start either
Old Nov 6, 2005 | 02:44 PM
civicEXtreme's Avatar
didn't read other posts but... did you hit the gas pedal when trying to start it up? SOme times you need to do that.
Old Nov 6, 2005 | 03:18 PM
808_si's Avatar
this probably is retarded, but is there any chance you bought diesel fuel on accident?
Old Nov 6, 2005 | 03:52 PM
elph925's Avatar
yeah man i have the same prob. just make sure you put atlease 2 galons in the tank... mine starts up fine now.
01_ITR
Apr 5, 2009 07:55 PM
almostboostedgsr
Mar 26, 2007 10:57 AM
menappi
Jun 21, 2006 04:01 PM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
JDMlyfestyle
19
Jan 7, 2004 08:16 PM
