Extremely loud, annoying irratating noise coming from under-neath my car...
Old Nov 4, 2005 | 04:37 PM
NoahOneill's Avatar
Default Extremely loud, annoying irratating noise coming from under-neath my car...
Okay so this just recently started happening about 3 weeks ago, when i was driving normally, and out of nowhere my car starts this really annoying rattling, it happens when i start it up, and when i start to rev, and then it stops around 3000 RPMs, i've looked underneath and i cant see anything that could really be causing it, i've checked under the hood and still didnt see anything, but i've pretty much narrowed it down to something underneath, anyone have any ideas as to what this could be?
Old Nov 4, 2005 | 04:40 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: Extremely loud, annoying irratating noise coming from under-neath my car... (NoahOneill)
Heatshields?
Old Nov 4, 2005 | 04:51 PM
NoahOneill's Avatar
Default Re: Extremely loud, annoying irratating noise coming from under-neath my car... (omega02379)
Not sure, i just went out again to see if i could possible see something rattling from underneath, but i didnt see anything.. I dont know TOO MUCH about cars, and i'm beginning to hate the one i have..
It's honestly to the point where it's so loud i feel like an idiot even driving the thing..
Old Nov 4, 2005 | 05:13 PM
G2 Speed's Avatar
heatsheild
or the exhaust.. baffels or w/e there called, I got the same problem.... I feel so embaressed going to school with it, or picking my girlfriend up from school ..... I honestly am like this sounds so gay lol... but wait till they here my mad VTAK!
Old Nov 4, 2005 | 05:17 PM
si0385.'s Avatar
Default Re: Extremely loud, annoying irratating noise coming from under-neath my car... (G2 Speed)
i had a problem with my ef hatch i had a exhaust and a short throw shifter and the shifter and when u went to go in reverse it would hit and make a loud anoying rattling noise
but what u got sounds like a heat sheild try moving them by hand to see if there loose
Old Nov 4, 2005 | 06:18 PM
EG2Driver's Avatar
Default Re: Extremely loud, annoying irratating noise coming from under-neath my car... (turbodreamz0385)
mine did that.....it was the heat shield between the gas tank and the pipe. You should be able to see it without jacking up the car
Old Nov 4, 2005 | 07:02 PM
NoahOneill's Avatar
Default Re: Extremely loud, annoying irratating noise coming from under-neath my car... (deadend9009)
Hmmm, so if it is the heatshields, how do i go about fixing this problem?
Old Nov 4, 2005 | 07:08 PM
TsukubaDreams's Avatar
heat shield right under your header... take it off cause its prob rusted to ****.
Old Nov 4, 2005 | 07:11 PM
NoahOneill's Avatar
Default Re: (TsukubaDreams)
Yea the car's got like 198k miles on it, thanks.
Old Nov 4, 2005 | 07:24 PM
VTAKKK!!'s Avatar
ya i put my money on heatshield
same thing happened in my eg
whenever idling or at certain rpm's it wast he one right below my e-brake so i just ripped it off
problem solved haha
Old Nov 6, 2005 | 05:00 PM
NoahOneill's Avatar
Default Re: (VTAKKK!!)
Does anything think they could show me a pic of where the headshields are underneath? I was looking in my car and couldnt see anything that seems like it would be rattling, maybe i'm just looking in the wrong place? (sorry i'm a nub. :x)
Old Nov 6, 2005 | 07:22 PM
NoahOneill's Avatar
Default Re: (NoahOneill)
Anyone?
Old Nov 6, 2005 | 07:58 PM
honda011's Avatar
it should be the heat shields..
Old Nov 6, 2005 | 08:17 PM
vietnameeh's Avatar
heatshield...mine does it right now....
also its make a rattling when accelraing from first
its heatshield
Old Nov 6, 2005 | 08:29 PM
CivicVX94's Avatar
i recently had this problem and it turned out to be the header bracket that holds the header up in the back to the block, had halfway broke and was vibrating against my intermediate shaft. good luck and bump
Old Nov 6, 2005 | 08:34 PM
MiX's Avatar
MiX
Default Re: Extremely loud, annoying irratating noise coming from under-neath my car... (CivicVX94)
no one answers your questions. I dont have a picture, but the heatshield is the part of the that covers the cat. Its the part right after the header. The cat is inside this shell and the shell is the heat shield. Take it to a mom and pop shop and they will just weld it for you. If its a small crack. Easy fix. I say mom and pop shop b/c its so fast and easy alot of times they wont charge you.
Old Nov 6, 2005 | 08:37 PM
RTI's Avatar
RTI
Heat shield, or could be the inner pipe inside the second part of the header (i think this is called the b-pipe). Not sure what kind of motor you have. If you have a staight-through type muffler sometimes the pipe breaks loose on one end and rattles pretty bad.
Old Nov 6, 2005 | 08:47 PM
riceburnerryan's Avatar
heat shield .... my car does it ... and people look at me funny .. then i show them whats up ... those *******...
Old Nov 6, 2005 | 08:55 PM
.Ry's Avatar
.Ry
Default Re: (riceburnerryan)
Have a buddy rev it when your on the ground and listen for it. Or hell jack it up and put it on jackstands and carefully crawl under there and have him rev it. PLEASE BE CAREFUL. Take it to a shop, they will put it up on a rack for nothing and show ya what the problem is. Sometimes if your lucky you can run a wire around it and tighten the heatshield up.
Old Nov 7, 2005 | 10:13 AM
NoahOneill's Avatar
Default Re: (turner7205)
Nice, thanks alot guys, i found it and it was indeed the heatshield. brought it to one of my moms friends and he fixed it for free.
Thanks
jacob4lester
Feb 3, 2010 10:14 AM
JDMSalvi55
Honda Civic (2001 - 2005)
Dec 18, 2007 12:03 AM
devgon2
Jul 6, 2007 05:16 PM
mugen_gangster
Aug 5, 2005 09:08 PM
Holding monSteR
May 4, 2004 02:00 PM
