TIRE SIZE ???
It's hard to say more than 17" or 18" because you don't say how wide the rims are. I would suggest however that you go to tirerack.com and look for tires that are the same diameter as your stock tires(so your speedometer will still be right). You have to decide how wide the rims are going to be and get tires that will fit that width. tirerack.com has all the specs for the tires. They might not have the exact brand you like, but a 195/60/15 is pretty much the same measurements, whatever the brand name.
http://www.tirerack.com/tires/index.jsp
Check it out, just pic any brand tire you like and click on the specs. tab. It will tell you which tires will fit that rim. First look up your stock tire size to get the diameter, so you can get some that are close to the same. I wouldn't go more than a half an inch taller, for diameter.
