Kteller exhaust problem
Old Nov 4, 2005 | 11:18 AM
zseeanz's Avatar
Default Kteller exhaust problem
Have a slight problem with my new 3" Kteller exhaust. This is where the pipes are suppose to slip over each other and attatched with the clamp. The 2 pipes are both the same diameter. Guess they weren't flared. What do I need to do? Where could I take it to have this fixed?
Old Nov 4, 2005 | 11:23 AM
goofyej6's Avatar
Default Re: Kteller exhaust problem (zseeanz)
Take it to a muffler shop and ask them to flare it or weld it on for you?
Old Nov 4, 2005 | 11:27 AM
zseeanz's Avatar
Default Re: Kteller exhaust problem (goofyej6)
think a muffler shop can flare it cause I wanna put it on myself. Maybe midas?
Old Nov 4, 2005 | 11:28 AM
goofyej6's Avatar
I pretty sure they can. Doesn't hurt to try
Old Nov 4, 2005 | 11:31 AM
Luserkid's Avatar
That looks stainless. Most muffler shops cant weld that. But they can flare it out without a problem.
jameskersten1's Avatar
flaring shouldnt be hard for any muffler shop. Take it to them and ask. Last time I need one flared, the shop near me did it for free.
Old Nov 4, 2005 | 11:48 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Kteller exhaust problem (jameskersten1)
Just push real hard.
Seriously, like the others said, take it to any local muffler shop. They will flare it for you no problem. I had to do that for a piece of piping as well a few years ago.
Old Nov 4, 2005 | 12:19 PM
zseeanz's Avatar
Thanks for the help. Guess I'll be going to midas tommorrow
Old Nov 4, 2005 | 01:06 PM
blazed_racer's Avatar
maybe a noob question here... but ive never seen exhuast pipes just flared, and pushed together and held together with a clamp...
im sorry but, wouldnt that leak???
Old Nov 4, 2005 | 01:29 PM
zseeanz's Avatar
Default Re: (blazed_racer)
As Long as the aft pipe gets flared to fit over the forward pipe, it shouldn't leak, am I right?
Old Nov 4, 2005 | 01:43 PM
KTeller8's Avatar
Default Re: (zseeanz)
no they wouldnt leak...
i cant tell by the pictures which side or section you posted. but try to take a clean stait and make sure that they are indeed not flared. thats odd cause most are preflared before they are bents. sometimes ppl need to clean or use sandpaper around the edges to help get them to slip into each other. they are basically flared very minimal to help from moving or leakage.. a .25" of flare or so..
let me know via pm and if the shop does charge you, please pm me the cost and well help you with that!
Old Nov 4, 2005 | 06:16 PM
Stripped Honda's Avatar
99-0104
take it to a muffler shop and they will weld the 2 pipes together ...
Old Nov 4, 2005 | 06:30 PM
ok cool so it wont leak...
whats the advantage of doing it this way, to say, a bolted flange?
Old Nov 4, 2005 | 06:39 PM
dfoxengr's Avatar
the slip is so the length is adjustable, thats the advantage over flanges.
i would throw the smaller end into a freezer or large bucket of iced salt water, for about 10 minutes, then simultaneously heat up the larger end gfor the last minute or two with a propane torch.
this will expand the larger end and contract the smaller. see if that works first.
KrisEJ6Hatch
May 17, 2011 08:38 AM
94sol_vtec
Feb 23, 2004 07:32 AM
civperc
Mar 26, 2003 06:30 AM
SyKoTiC_ReX
Jun 29, 2002 03:17 PM
