Off the line whos faster ls or gsr.. first 60 feet..
Old Nov 4, 2005 | 11:14 AM
Ls-Turbo's Avatar
Default Off the line whos faster ls or gsr.. first 60 feet..
just curious i hear alot of rumors.. that the ls is quicker off the line due to the longer stroke.. but then the gsr tranny has a shorter gear ratio..
Old Nov 4, 2005 | 11:17 AM
sPaRk'iT's Avatar
Default Re: Off the line whos faster ls or gsr.. first 60 feet.. (Ls-Turbo)
I would say the driver but im a Ls owner and i have taken off on a few GSR's off the line before and some all the way to 3rd gear. But alot of people in here might have a different story.
dudefella's Avatar
I'd say whoever's the better driver
Old Nov 4, 2005 | 11:30 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Off the line whos faster ls or gsr.. first 60 feet.. (dudefella)
Same car/same driver skill, then technically the LS will be faster off the line. Very small torque difference.
Real world conditions = depends on driver skill.
Old Nov 4, 2005 | 12:53 PM
halozero's Avatar
Default Re: Off the line whos faster ls or gsr.. first 60 feet.. (shamoo)
i was under the impression gsr had long gears? maybe that's just opposed to b16 / b18r
Old Nov 4, 2005 | 12:59 PM
stocker2shocker91's Avatar
I requested a short story for a title.
ive heard that an ls is pretty good in the hole shot. i got one and it pretty strong.
Old Nov 4, 2005 | 01:44 PM
vtecmissle's Avatar
the gsr has a 4.40 fd and shorter gearing. In theory it would lay down more torque in every gear regardless of the difference in torque in the ls and gsr. The gsr also lays down more peak torque the ls has more at a lower rpm. GSR 0-60 second time is faster period. It may be driver differences i have seen this myself.
Old Nov 4, 2005 | 03:04 PM
97tegGS's Avatar
http://media.putfile.com/ThirdRunT
This was a run at the dragstrip I had. Im the silver Ls againt the black gsr with boltons
I ran a 15.9 and he ran a 15.2
He launched at 4 me a 2.5k
I had him by a little bit off the line
Modified by 97tegGS at 10:33 PM 11/4/2005
Old Nov 4, 2005 | 09:32 PM
Ls-Turbo's Avatar
Default Re: (97tegGS)
humm.. still kinda obscure..
Old Nov 5, 2005 | 01:45 AM
watsvtecEK's Avatar
Default Re: (Ls-Turbo)
did ihear the words "red light" from someone on the side of the strip?
Old Nov 5, 2005 | 04:27 AM
97tegGS's Avatar
we both did. I was -.006 and he was -.010
Old Nov 5, 2005 | 10:07 AM
Ls-Turbo's Avatar
so no one really has evidence huh.. so if the same driver drove a gsr and the ls which one would do better the first 60 feet
Old Nov 5, 2005 | 11:18 AM
97CGPintegra's Avatar
i think 60 feet is too short to tell the difference. they should be very close.
low430's Avatar
the LS is faster for the first 60 FT but its all driver, and how you launch. LS has a bit more TQ but if you know what your doing you can work the GSR to be faster its just HARDER on the motor
Old Nov 5, 2005 | 01:05 PM
dohcMONSTER's Avatar
driver
Old Nov 5, 2005 | 01:33 PM
killaBc1's Avatar
Default Re: Off the line whos faster ls or gsr.. first 60 feet.. (dohcMONSTER)
suspension and tires win this battle.
Old Nov 5, 2005 | 03:58 PM
95TegSE's Avatar
Default Re: (low430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 &raquo;</TD></TR><TR><TD CLASS="quote">the LS is faster for the first 60 FT but its all driver, and how you launch. LS has a bit more TQ but if you know what your doing you can work the GSR to be faster its just HARDER on the motor</TD></TR></TABLE>
The LS doesn't actually have more torque, it just reaches a peak earlier in the powerband than the GSR.
Old Nov 5, 2005 | 04:01 PM
low430's Avatar
Default Re: (95TegSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">
The LS doesn't actually have more torque, it just reaches a peak earlier in the powerband than the GSR.</TD></TR></TABLE>
your a retard....
they have different bore and stroke
The LS does have more torque
Old Nov 5, 2005 | 04:14 PM
integra3586's Avatar
Default Re: (vtecmissle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">the gsr has a 4.40 fd and shorter gearing. In theory it would lay down more torque in every gear regardless of the difference in torque in the ls and gsr. The gsr also lays down more peak torque the ls has more at a lower rpm. GSR 0-60 second time is faster period. It may be driver differences i have seen this myself.</TD></TR></TABLE>
the first two gears in both the ls and gsr are identical. i know 3rd 4th, in the gsr are shorter, im not positive about the 5th gears,
Old Nov 5, 2005 | 04:23 PM
maggsgsr's Avatar
Default Re: (integra3586)
Maybe the first 60 feet, 0-60 GSR runs better times period. The LS peaks out when the GSR just get's going. I could see it may have an advantage for the first 30-60 feet then the GSR starts hitting it's peak.
Old Nov 5, 2005 | 04:26 PM
low430's Avatar
Default Re: (maggsgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maggsgsr &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the first 60 feet, 0-60 GSR runs better times period. The LS peaks out when the GSR just get's going. I could see it may have an advantage for the first 30-60 feet then the GSR starts hitting it's peak.</TD></TR></TABLE>
Answer the Question, Off the Line LS is faster WTF is wrong with people.
We all know GSR is faster up top so give LS the Credit that its faster off the line.
Off the Line LS &gt; GSR
1/4 Mile GSR &gt; LS
Assuming Equal drivers of course
Is that hard to understand?
Old Nov 5, 2005 | 05:03 PM
Dogginator's Avatar
Daisy... Daisy...
your a retard....
The degree of ignorance in threads like this makes my head hurt.
Quite simply, the B18C1 (GSR) and B18B (LS) share an identical 81mm bore. The B18C1 and B18B have a 87.2mm and 89.0mm stroke, respectively. The B18C1 and the B18B have a 10:1 and a 9.2:1 compression ratio, respectively. Finally, the B18C1 and the B18B produce 128ft-lb and 127ft-lb of torque, respectively. The compression ratio trumps the stroke, and the GSR has more torque.
If you really want to find out which one is faster, find some magazine data for 5-60 MPH, which essentially eliminates the influence of the driver.
Old Nov 5, 2005 | 06:26 PM
projectTeG's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
If you really want to find out which one is faster, find some magazine data for 5-60 MPH, which essentially eliminates the influence of the driver.</TD></TR></TABLE>
the ls doesnt create a HUGE amount more tq than the gsr...its just the ls feels torquyer because its peak power is lower, due to downsyndromed head....and small cams
Old Nov 5, 2005 | 06:37 PM
1997GS-R's Avatar
this whole LS vs GS-R is old....and if I remember right the LS makes about 1 ft/lb of torque more than the GS-R and its peak torque/hp is made at a lower RPM than the GS-R so the LS may be slightly quicker off the line if the GS-R does not launch in the upper RPM band... but the GS-R will pass the LS very shortly after...assuming tires/both drivers are equal
Old Nov 5, 2005 | 06:52 PM
dc4g's Avatar
Default Re: (1997GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1997GS-R &raquo;</TD></TR><TR><TD CLASS="quote">this whole LS vs GS-R is old....and if I remember right the LS makes about 1 ft/lb of torque more than the GS-R and its peak torque/hp is made at a lower RPM than the GS-R so the LS may be slightly quicker off the line if the GS-R does not launch in the upper RPM band... but the GS-R will pass the LS very shortly after...assuming tires/both drivers are equal
well put
