How much power can the stock h22 valves/retainers take?
I am looking to make inbetween 300-400hp on a boosted h22 engine, should I look into changing the valves? or retainers?
Thanks
Thanks
Can I reseat the original valves or will I have to buy new ones?
The bottom end AFAIK cannot be boosted above 7-8 PSI due to the weak sleeves?
Just get your block sleeved with Darton, Benson, GE sleeves and some forged pistons. I think you can go a little higher than 7-8 PSI on the stock rods but while you gotr everything apart its worthwhile buying some forged rods.
Ive got Darton Sleeves, CP pistons (9:0:1 compression), and Crower rods. ARP head bolts, and cometic head gasket. Hopefully that little lot wont give me any problems
weak ringlands on the pistons prevent anything higher then 7-8 lbs.
No need to cut new seats for the valves unless the current ones are damaged or excessivly worn. New seals are recommended after pulling head. Also have it checked for warpage and pressure tested. Make sure you loosen the head bolts in proper sequence in 3 steps.
96SR-V
Apr 7, 2002 10:59 AM
