**Guage cluster doesn't light (diagram needed)
Old Nov 3, 2005 | 11:12 PM
jfoster's Avatar
Default **Guage cluster doesn't light (diagram needed)
Well this happend after I installed the stock head unit from my '01 GSR into my '95 LS ... but I'm not pulling the HU out again, I just got it in there with a new harness and the wide band is mounted under it .......etc
I do have Defi D guages (boost/oil pres/EGT) that still light up with the headlights, just the cluster doesn't light.
I have checked all my fuses multiple times without finding any blown. I also pulled my guages/cluster/bezel out and rechecked all the connections I made when I installed the guages, but everything checks out.
So I guess what I need is
1. To know exactly which fuse controls the lighting of the cluster... so I can recheck it just to be triple sure.
2. To know which wire running into the back of the cluster is supposed to come on with the headlights.
TIA
Old Nov 7, 2005 | 09:31 AM
APEX CRX's Avatar
Default Re: **Guage cluster doesn't light (jfoster)
Did you make sure the dimmer switch isn't unplugged or turned down?
Old Nov 9, 2005 | 05:18 PM
jfoster's Avatar
Default Re: **Guage cluster doesn't light (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">Did you make sure the dimmer switch isn't unplugged or turned down?</TD></TR></TABLE>
I have my EGT guage in the dimmer switch hole. I extended the wires to the dimmer switch and hid it behind the dash. I also used the dimmer switch wires for illumination of the new guages. All guages(stock and Defi) have worked fine since the install (couple months ago) until now. I did check the switch, position made no difference. I aslo tested it at the switch and before and after each connection I made... no dead spots....
Old Nov 9, 2005 | 06:32 PM
Heylookits shawn's Avatar
when i put in my new deck i forgot to unplug the battery and my cluster/climate control wouldnt light up. i forgot what fuse i blew though, i cant think of what its called right now
Old Nov 9, 2005 | 06:59 PM
SYTFU Tommy.'s Avatar
Default Re: **Guage cluster doesn't light (Heylookits shawn)
try the fuse udner the hood called B+ latern or something. it should be a 15amp fuse
kcrxxx
Apr 2, 2008 08:13 PM
projsectEF
12
Feb 10, 2007 08:13 PM
nevin
Aug 22, 2005 12:11 AM
WRS2K
Honda S2000
May 12, 2005 09:38 AM
