itr lsd in 00 b16 trans
Old Nov 3, 2005 | 04:57 PM
gc92cvc's Avatar
Default itr lsd in 00 b16 trans
puttin a type r lsd in a b16 i have a gsr ring gear on the diff already and i knw i have to shim it for proper gear hieght...do i have to shim both sides of the diff between the case and the case bearing? whn i put the diff in to test fit the ring gear or somethin seemed to b rubbing on the inside of the case...also is there anything else i need for the install someone told me i might need to change my counter shaft also...i have searched but havent found a definite answer. please help!!!!
jdm jedi
Transmission & Drivetrain
Jun 8, 2011 04:14 PM
Ti3d in
Mar 16, 2009 02:46 PM
unknown0001
Jan 18, 2006 01:43 PM
