ecu in limp mode, cut J1 and car ran ok. looking for ideas.
Old Nov 3, 2005 | 04:54 PM
Acura_I-RS's Avatar
Default ecu in limp mode, cut J1 and car ran ok. looking for ideas.
ls vtec integra obd1, chipped p28 ecu, i chipped myself..
i started it, and it ran, but only revved to about 4k rpms. with a solid cel. so i cut the j1 jumper, and the car runs ok, but idles at 2k rpms.. and now after i cut j1, there is no CEL.
i dont get it.
Old Nov 3, 2005 | 06:04 PM
Papa John's Avatar
the same exact thing happen to me; 4k rpm, solid cel, but I didn't cut the jumper please tell me what that would do?
Old Nov 3, 2005 | 06:38 PM
Acura_I-RS's Avatar
Default Re: (Papa John)
cutting the jumper will bring the ecu back into stock mode. by passing the external rom.
Old Nov 3, 2005 | 06:49 PM
Jim Truett's Avatar
Default Re: ecu in limp mode, cut J1 and car ran ok. looking for ideas. (Acura_I-RS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_I-RS &raquo;</TD></TR><TR><TD CLASS="quote">ls vtec integra obd1, chipped p28 ecu, i chipped myself..
i dont get it.</TD></TR></TABLE>
There are five possibilities:
1. The chip was installed backwards and that killed it.
2. The .bin file on the chip is corrupt.
3. There is a problem with your soldering
4. Your 74HC373 latch is bad.
5. If you are using a 28 pin socket, it is possible that not all of the ROM chip pins are making contact.
Old Nov 3, 2005 | 07:22 PM
Acura_I-RS's Avatar
Default Re: ecu in limp mode, cut J1 and car ran ok. looking for ideas. (Jim Truett)
well, i did desolder the 74HC373 latch and resolder it into the new ecu, i tried making a new bin, made sure the chip was in right every time, as far as i can tell, soldering looks good.
Old Nov 3, 2005 | 07:24 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_I-RS &raquo;</TD></TR><TR><TD CLASS="quote">well, i did desolder the 74HC373 latch and resolder it into the new ecu, </TD></TR></TABLE>
That might have overheated it. Do you have a Radio-Shack near by? They should have a 74HCT373 on the shelf. Can you check your solder joints with a DMM?
Old Nov 3, 2005 | 08:09 PM
Acura_I-RS's Avatar
radio shack didnt have the chip there.. i already checked.. thats why i reused it...
Old Nov 4, 2005 | 06:58 PM
SVOboy's Avatar
I'd go get another hc373, it is likely you burnt it desoldering it.
Old Nov 5, 2005 | 05:45 AM
Acura_I-RS's Avatar
Default Re: (SVOboy)
what exactly is the function of that chip?
Old Nov 5, 2005 | 10:11 AM
Acura_I-RS's Avatar
Default Re: (Acura_I-RS)
ok, i got another 74HC373 chip, is there anythign else i shoudl do when changing this chip out then?
Old Nov 5, 2005 | 12:02 PM
SVOboy's Avatar
Just take to old one out and solder the new one in, be sure not to tear any traces. I think its just a gate, and tells the ecu where to get data on the eprom, not sure though.
bigblue7t6
Engine Management and Tuning
Aug 31, 2012 02:42 PM
B20Luder
Aug 1, 2010 04:14 PM
Acura_I-RS
Oct 30, 2005 09:06 AM
Mr.Death
Jul 9, 2005 06:50 PM
