B20A3(Carbureted), Swap to Fuel Injection?????
I have a 1988 Prelude S, and I was wondering if it is possible to swap to the Si fuel injection setup, and what all I would need to do this. I can get an intake manifold, fuel rail and fuel injectors off a 1989 Si for about $30....What else would I need??? ECU?? Wiring Harness???? Please let me know if anyone has done this.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pody3kgt »</TD></TR><TR><TD CLASS="quote">I have a 1988 Prelude S, and I was wondering if it is possible to swap to the Si fuel injection setup, and what all I would need to do this. I can get an intake manifold, fuel rail and fuel injectors off a 1989 Si for about $30....What else would I need??? ECU?? Wiring Harness???? Please let me know if anyone has done this.....</TD></TR></TABLE>
The short answer? A donor FI car.
All the stuff you mentioned would be good. And the FI gas tank I think. Possibly some other stuff.
You'll need basically what they mentioned. Do a search in the EF Civic/CRX Forum for DPFI to PGMFI swaps (try carb as well). It's a fairly similar approach & may give you a little guidance, since it's a common upgrade for the EF's.
underage
May 24, 2005 02:28 PM
