a6 head on z6 block. which timing belt?
Old Nov 3, 2005 | 01:55 PM
hmtcrxsir's Avatar
Default a6 head on z6 block. which timing belt? need help fast!
I know this is a weird setup, but i blew the head. And i have an extra a6 head laying around. So i dropped that to the z6 block. And I tried using the Z6 timing belt. And it seems to be a bit short. And its very tight, can not even put belt on the tensioner. What timing belt should i use?
Is it true that i have to buy the timing belt that matches the head and I should be fine?
Modified by hmtcrxsir at 3:23 PM 11/3/2005
Old Nov 3, 2005 | 02:54 PM
sohc_turd's Avatar
Default Re: a6 head on z6 block. which timing belt? need help fast! (hmtcrxsir)
a6 T belt. Its gonna drop your compression down low.
Old Nov 3, 2005 | 03:02 PM
elph925's Avatar
Default Re: a6 head on z6 block. which timing belt? need help fast! (unbanned_evosol)
use the a6 my friend
Old Nov 4, 2005 | 01:09 AM
hmtcrxsir's Avatar
Default Re: a6 head on z6 block. which timing belt? need help fast! (elph925)
freaking im having problems installing the timing belt. I used the z6 tensioner and a6 timing belt. The belt seems to be a bit loose and when i used the a6 tensioner and a6 timing belt. The timing belt is also loose. Im so confused and dont know what timing belt to use now.
When i tried turning the crank by with the timing belt installing. The timing belt would pop out and go back again. So i know its loose. Could it be that i am using a timing belt from AutoZone? I know it would be better if i were to get a OEM one. But they want too much for it.
Well actually the block is a JDM D16a (similar to a z6) could it be that much of a difference?
Old Nov 4, 2005 | 10:07 PM
sohc_turd's Avatar
it wont' matter what block it is, as long as the belt matches the head. Are you taking the proper steps to tighten the belt? Loosen tensioner, turn counter clockwise 2 complete turns then tighten.
one-cam
Aug 15, 2008 08:11 PM
slor209
Mar 12, 2008 01:41 PM
175Shot4Door
Nov 6, 2006 12:50 PM
tonesdef
Jul 8, 2003 10:22 AM
BauleyCivic
Jul 5, 2003 03:09 PM
