removing rear quarter window's Unbolt,Screw, ect??
My Car:90 civic hatch.
I posted a while back about how some num nuts ran me off the road. Now Im at the point of getting it fixed and the hole car is getting sprayed!
But I need to remove the rear pop up quarter windows.
Once I detach the pop up latch, do I need to unbolt the hinge near the door or what?
A pic of pitty for my dumb *** would be much appreciated!!!!
Thanks guys-
Thanks guys-
Remove the screw that holds the black cover on the pillar.
Remove the black cover.
Remove screws under the cover.
Remove the screws under the cover in the back where the clamp is.
It is really easy.
It is really easy.
Not to be a bone-afied dumbass, but are you referring to the "B" pillar next to the seat belt or the pillar in the back wear the pop out latch is??
Truefully I need the best concept of removal of the "B" pillar latches
(Yes I know--What a dumb *** I be....)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclized »</TD></TR><TR><TD CLASS="quote">Not to be a bone-afied dumbass, but are you referring to the "B" pillar next to the seat belt or the pillar in the back wear the pop out latch is??
The first part is the pillar right inside your door opening. The clamp part, is the ne in the rear in the hatch area.
</TD></TR></TABLE>The first part is the pillar right inside your door opening. The clamp part, is the ne in the rear in the hatch area.
acmoc
Apr 5, 2010 09:21 AM
dinosa21
Feb 6, 2003 08:55 PM
citanest
Oct 27, 2001 04:51 AM
