how to "install eagle rods in a dohc zc??
im tryin to build my dohc zc.....and today my eagle rod's came....but they are a solid piece, im not sure how to put them on the crank. stock rods have removeable caps, but the eagle rod's do not....can someone help me??
Just get a cutting torch and try to make a straight line about where you think they caps would be.
When you put em on the crank, weld em back up nice and smooth so they fit tight on the crank.
Poof, no worries after that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">BWAHAHAHAHA
Cmon man, obviously they have caps
</TD></TR></TABLE> i would of thought they would, the rod's have bolts in it(like it would have caps) but the rod is a solid piece<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler »</TD></TR><TR><TD CLASS="quote">Just get a cutting torch and try to make a straight line about where you think they caps would be.
Poof, no worries after that </TD></TR></TABLE>are you joking????!!! that doesnt sound like the right way to install these
Yes, im joking.
The rods have caps. They are very well made, and probably just have a very tight seam.
Dont pry with anything metal. Just take the bolts off and gently work the caps off.
this is the method i used
J/K
if they dont have caps then they sent you some rods that were not finished bro.......
J/K
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 »</TD></TR><TR><TD CLASS="quote">If you can't figure out how to get the end caps off rods....you sure as hell shouldn't be building your own engine.</TD></TR></TABLE>
qft
qft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler »</TD></TR><TR><TD CLASS="quote">Yes, im joking.
</TD></TR></TABLE>thanks ill look at the seem<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">Not trying to be offensive, but maybe you shouldn't build an engine on your own...</TD></TR></TABLE>im not building it on my own...but i still want to learn how to do the stuff, im going to school for this....but like i said id like to know what's going on with my build<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 »</TD></TR><TR><TD CLASS="quote">If you can't figure out how to get the end caps off rods....you sure as hell shouldn't be building your own engine.</TD></TR></TABLE>wow captin obvious (is there anything else you would like to repeat???)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler »</TD></TR><TR><TD CLASS="quote">
qft</TD></TR></TABLE>huh??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon »</TD></TR><TR><TD CLASS="quote">Use the right tool's, when you do install them
</TD></TR></TABLE> i will thats the good thing about going to an auto-tech school....i have all kinds of tools and lifts and air tools
qft typically means "quoted for truth". As stated above, your lack of knowledge on the subject (no offense) tends to alarm some of us who thought you were building it alone.
As you have cleared this up, then its no problem
Good luck with your build. Go slow, and be deliberate. Dont buy **** you dont need. Measure twice, cut once young padwan.
First, other than having all the required tools... you should have a detailed service manual or spend time on the internet finding everything to need to learn. Head over to your local book store or library and start studying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by islandtechengineers »</TD></TR><TR><TD CLASS="quote">First, other than having all the required tools... you should have a detailed service manual or spend time on the internet finding everything to need to learn. Head over to your local book store or library and start studying.</TD></TR></TABLE> yeah your right, since i started this project...it feels like im on ht 24/7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">im tryin to build my dohc zc.....and today my eagle rod's came....but they are a solid piece, im not sure how to put them on the crank. stock rods have removeable caps, but the eagle rod's do not....can someone help me??</TD></TR></TABLE>
i need pics of this, dude all rods you can take off the caps.
sorry forgot to update: rods do have cap's the seem was just so damn clean i couldnt see it...man i cant wait to put these in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">sorry forgot to update: rods do have cap's the seem was just so damn clean i couldnt see it...man i cant wait to put these in
</TD></TR></TABLE>Did you have to beat them on concrete? Thats how I got my caps off. Just took the rods outside and banged them on concrete until they finally gave up. ******* Rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ih8jdm »</TD></TR><TR><TD CLASS="quote">Did you have to beat them on concrete? Thats how I got my caps off. Just took the rods outside and banged them on concrete until they finally gave up. ******* Rods.</TD></TR></TABLE>
um, i wouldnt beat my new manley rods (500 bucks) on concrete, i used a mallet and a block of wood, much safer for your rod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">chop saw worked for me
Then I welded my cam to my valves for super high lift</TD></TR></TABLE>
I tried this once, but had to use washers for more duration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">um, i......beat my.......manley..................................w ood, much safer for your rod
</TD></TR></TABLE>???
