NO SPARK, NO FUEL, NEW (PGMFI) MAIN RELAY! WTFF??!!?
Old Nov 3, 2005 | 12:23 PM
hondahatch741's Avatar
Default NO SPARK, NO FUEL, NEW (PGMFI) MAIN RELAY! WTFF??!!?
im helped a friend do sum maintenance to his car. i changed his thermostat,radiator,headgasket, and a couple of other gaskets that were all old and fucked up along the way.. the car was sitting for about a year. so i took all the gas out the the tank through the fuel filter and put new gas in.. it started great. i went home n went bak to his house the next day becuase he told me the car wont start again.. it wasnt getting fuel but it was getting spark. so i take out the (pgmfi) main relay and jump the fuel pump from it and it got fuel but didnt get spark.. so basically it only gets fuel wen jumped and only gets spark wen the relay is in.. i told him to go to acura and buy a new relay and he did but told me that acura dicontinued the relay and came out wit a upgraded model.. i put the relay in and still no fuel .. now im thinking maybe thge relay was faulty so he returned that one and got a new one.. same ****! nothing happened.. now i donno wha to do.. please help me im all out of ideas.. o yea and there is no check engine light.. could it b the wiring fried? i live in florida and the car was sittin in the sun for a year wit no car cover on. could it have been the ecu? maybe it shorted out becuase of the heat the soldering might have got fucked up.. i donno and i wanna get this car running already.. please give me any ideas as to what it might b.. thanks!
Old Nov 3, 2005 | 02:23 PM
Chiovnidca's Avatar
Default Re: NO SPARK, NO FUEL, NEW (PGMFI) MAIN RELAY! WTFF??!!? (hondahatch741)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahatch741 &raquo;</TD></TR><TR><TD CLASS="quote"> i changed his thermostat,</TD></TR></TABLE>
Did you reconnect the ground wire to the t-stat housing? Check fuses?
Old Nov 3, 2005 | 03:11 PM
Default Re: NO SPARK, NO FUEL, NEW (Chiovnidca)
i did i checked everysingle fuse in the whole car .. none are blown
Old Nov 3, 2005 | 05:59 PM
mugenboi's Avatar
Did you check for fuel pressure? Even though you can hear the fuel pump "click" doesnt mean that it is working.
Old Nov 3, 2005 | 06:05 PM
Default Re: (mugenboi)
no i didnt check it.. but the fuel pump pumps fuel only wen i jump it tho when the relay is in it wont work.. im thinking its an electrical problem.. do u kno of a way i can troublshoot or sumthing.. i donnooo.. but i am running out of patience
Old Nov 4, 2005 | 06:06 AM
SOHFAST94's Avatar
Default Re: (hondahatch741)
Hows about the fuel pump ground on the T-stat along with the ignitor in the distributor?
Old Nov 4, 2005 | 01:48 PM
Default Re: (SOHFAST94)
i didnt even know there was a ground for the fuel pump on the t-stat.. wheres it at? on the housing? and why would it b there if you doint mind me asking what does the t-stat have to do with fuel?
Old Nov 4, 2005 | 02:28 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahatch741 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt even know there was a ground for the fuel pump on the t-stat.. wheres it at? on the housing? and why would it b there if you doint mind me asking what does the t-stat have to do with fuel?</TD></TR></TABLE>
The little ground wire bolted to the t-stat housing is the main ground for the pgmfi system. Not a clue as to why they put it there, but they've been putting it there for over 20 years now.
Old Nov 4, 2005 | 02:29 PM
Default Re: (Chiovnidca)
hymm i check that tommorow then.. thanks
Old Nov 4, 2005 | 05:36 PM
eg2.0dart's Avatar
had the same problem-ecu check it with someone elses computer.
keslerbuilt
Jan 26, 2014 09:50 AM
Lb1atx
Aug 1, 2007 10:52 PM
dc96819
Jun 4, 2007 10:18 PM
hondahatch741
Nov 3, 2005 12:21 PM
1hotintegra
Aug 25, 2004 01:03 PM
