Climate Control Button Lights.... Already Search
Old Nov 3, 2005 | 11:23 AM
T_bones's Avatar
Default Climate Control Button Lights.... Already Search
I have a 95 integra ls. My Climate Control lights up fine. Its the buttons that dont light up when the buttons are pushed in. I done switch Climate Control with 3 different ones still dont fix it. The heat comes on and everything but it comes out everywhere and wont switch over to just blow out in the floor or straight out, or just defrost. Any help would be appreciate Thanks.
Old Nov 3, 2005 | 12:36 PM
T_bones's Avatar
Default Re: Climate Control Button Lights.... Already Search (TEGhasJDMfever)
Anyone??
Old Nov 3, 2005 | 12:47 PM
maniefrizzle's Avatar
probably the bulbs blew. you either have to change the bulb or replace the button. i have the reverse problem. my buttons light up when pressed but does not have the lit background.
Old Nov 3, 2005 | 12:48 PM
rdblckSV650S's Avatar
Default Re: Climate Control Button Lights.... Already Search (maniefrizzle)
go to your dealer and ask for a replacement bulb for both buttons. They're the only place that's going to have those obscure bulbs.
Old Nov 3, 2005 | 12:49 PM
T_bones's Avatar
nope not the bulbs... replace the climate control with 3 different ones.... fan will not switch over when hit the buttons, from like blowing straight out to blowing just defrost.... it just blows out everywhere.
Old Nov 3, 2005 | 12:54 PM
if its not the bulbs and you tried 3 different ones, then it has to be the connectors to the unit. did you snap it back on the climate control? and you probably didn't attach the metal wire to the white plastic inside, maybe that's why air is blown everywhere.
Old Nov 3, 2005 | 01:06 PM
T_bones's Avatar
I got the 2 plugs for the hazard and rear defrost pluged up, the 2 plugs for the climate control pluged up, the metal wire that changes it from hot to cold hooked up. Just dont know what the problem could be.
Old Nov 3, 2005 | 01:49 PM
T_bones's Avatar
anyone else have this problem and can tell me what they did to fix it?
BOTAN01
Dec 20, 2007 11:15 AM
eghatchomar
Mar 28, 2005 08:07 PM
dip-set
Aug 25, 2003 01:51 PM
SupaTegRS
Jan 8, 2003 09:51 PM
