attn: COMPTECH tie bar question
I have purchased a used Comptech tie bar w/ 99-00 Civic Si 13mm rear sway bar + SI endlinks.. which improved my handling alot.. right now I'm trying to figure out if I should plan on upgrading to a thicker sway bar but, I dunno if I'd need to since my suspension is pretty stiff already.. (Omni Power Coilover kit SPORT 12k front/ 10k rear).
I'm debating on these for an upgrade.. so which one would you guys get?
- ITR rear sway bar 22mm
- Blox rear sway bar 21mm
my current setup..
thanks-
my current setup..
thanks-
Its really up to you...
Every person have a different feeling of happiness with their car.
Some people like all stock ITR springs/shocks for auto-xing.
Some like a rock hard suspension...
Its up to you. I went with a thicker 22mm bar because the SI was not working for me. I kept loosing traction in the rear on hard turns...
Now with the si sway up front and the 22 in the back, 11k front, 7 k rear, I'm pretty happy with everything. Its like a neutral feel.
So, do you think you need something bigger???
well, I just ordered the ITR sway bar, D brackets, and bushings... it should be here next week... amma just try it out and see how it feels... thanks-
96 SOHC VTEC
Jun 12, 2002 01:04 PM
